Rubber Wheel 136×24mm (Kit)
$29.90
SKU: KIT0044
  • $29.00 2+ items
  • $28.00 4+ items
  • $26.00 10+ items
Custom black rubber wheel kit includes two 136mm tires, couplings, screws, and washers. Ideal for indoor mobile robots, offering anti-slip and firm grip.
This is a DFRobot designed black rubber wheel kit. The custom-designed kit contains two 136mm rubber tires tested over 6 indoor conditions,packed with shaft couplings, two M8 screws and 2 washers. Designed to fit on DFRobot HCR(Home Care Robot) platforms and other indoor mobile robots, the dent on the wheel has a good anti-slip effect and provide a firm grasp over the moving surface. Our tailored couplings is your best choice to consider,but you can also use your own couplings.
Wheel Specification
  • Custom-designed rubber wheel
  • Fits on DFRobot HCR(Home Care Robot) platforms
  • Diameter: 136mm(outer)(5.35") 18mm(inner)(0.71")
Coupling Specification
  • Rubber Wheel 136×24mm(5.35x0.94")   x2
  • Washer   x2
  • Shaft Couplings    x2
  • M8 Screw   x2
Only 8 Left
