RS485 Shield for Arduino
$9.90
SKU: DFR0259
  • $9.70 2+ items
  • $9.50 5+ items
  • $9.30 10+ items
The RS485 shield adapts the Arduino to industrial communication, converting UART to RS485 protocol. It features automatic/manual modes, a reset switch, and a welding area.
Purchase this product and earn 106 reward points, which are tied to VIP membership program. Learn More >
RS485 is an industrial standard for long-distance, anti-interference, and reliable communication. The Arduino RS485 shield, specially designed for the Arduino Uno board. It converts UART/Serial protocol to the RS485 protocol.  This RS485 board allows Arduino talk to industrial devices.
In contrast to RS-422, which has a single driver circuit that cannot be switched off, RS-485 drivers use three-state logic allowing individual transmitters to be deactivated. This allows RS-485 to implement linear bus topologies using only two wires. The equipment located along a set of RS-485 wires is interchangeably called nodes, stations, or devices.
  • Integrated a standard RS485 port, a mini RS485 port, RS485 headers
  • Provide the welding areas to make full use of the free space. And more importantly, it's convenient for your DIY design.
  • Switch between automatic mode and manual transmission mode, which expands the scope of application.
  • Besides Tx/Rx interface, there is a switch to block/disable this shield, when Arduino needs to be programmed.
  • Gold immersion PCB. Long pins on the back adapt to most Arduino controllers.
Arduino RS485 Shield Demo Project
What is RS485?
"RS-485 enables the configuration of inexpensive local networks and multidrop communications links. It offers data transmission speeds of 35 Mbit/s for distances up to 10m and 100 kbit/s up to 1200 m. Since it uses a differential balanced line over twisted pair (like RS-422), it can span relatively large distances up to 1,200 m (4,000 ft). A rule of thumb is that the speed in bit/s multiplied by the length in meters should not exceed 10^8. Thus a 50-meter cable should not signal faster than 2 Mbit/s." From Wiki.
Note: The screws for the terminal blocks may have slightly different cross-head styles. Both versions work perfectly with a standard Phillips head screwdriver.
  • Power module: +5V
  • Module size: 55mmx53mm(2.16"x2.08")
  • 16 digital IO ports (including an I2C interface)
  • 6 analog IO ports and power
  • Operation and programming mode switch
  • Automatic and manual transceiver mode switch (When in manual transceiver mode, the enable end is the 2nd digital IO port)
  • Transceiver indicating LED
  • Standard RS485 interface, mini RS485 interface, and RS485 pins
  • Welding area
  • Reset switch
  • PH2.0 sensor interface for DFRobot RS485 series sensor: URM04 Ultrasonic sensor
  • RS485 Arduino shield     x1
Certifications
