Ethernet Shield for Arduino - W5200
$17.90
SKU: DFR0272
  • $17.30 3+ items
  • $17.00 5+ items
  • $16.50 10+ items
The Ethernet Shield connects Arduino to the internet using the W5200 chip, enabling TCP/IP protocols, SPI integration, microSD storage, and power management.
DFRduino Ethernet Shield for Arduino brings reliable wired networking to embedded projects through the W5200 hardwired TCP/IP Ethernet controller. Designed for seamless stacking with Arduino UNO and Mega boards, this Ethernet expansion board enables microcontroller systems to connect directly to local networks or the Internet through a standard RJ45 cable. Integrated hardware TCP/IP processing dramatically reduces firmware complexity while maintaining stable communication. An onboard microSD card interface adds large-capacity storage for web resources, logs, or configuration files, making this networking shield suitable for IoT gateways, data servers, and connected automation systems.
Hardware TCP/IP Networking with W5200
The networking expansion board is powered by the W5200 Ethernet controller, a fully hardwired TCP/IP solution integrating Ethernet MAC and PHY with a proven protocol stack. Built‑in support for TCP, UDP, IPv4, ICMP, ARP, IGMP, and PPPoE allows embedded developers to implement reliable Ethernet communication without managing complex networking stacks in firmware. A 32KB internal buffer handles transmit and receive operations efficiently, while eight independent hardware sockets allow multiple simultaneous network connections, enabling applications such as web servers, remote monitoring nodes, and connected industrial controllers.
Efficient SPI Integration for Embedded Systems
This SPI-based Ethernet interface module communicates with host microcontrollers using a simple four‑wire Serial Peripheral Interface. Such architecture minimizes I/O consumption while maintaining high data throughput, making the board suitable for compact embedded designs where pin availability is limited. Support for SPI Mode 0 and Mode 3 ensures compatibility with common microcontroller platforms. Hardware features such as Wake-on-LAN and power‑down operation further improve system energy efficiency, supporting low‑power connected electronics and remote wake‑up network applications.
Integrated microSD Storage for Network Applications
An onboard microSD card slot expands functionality beyond basic connectivity by enabling large-capacity data storage directly on the networking shield. Embedded web servers can store webpage resources locally, while data‑logging systems can archive sensor records or network traffic logs. Such storage capability is particularly useful for IoT gateways, automation dashboards, and distributed monitoring platforms where network communication and persistent data storage must coexist within a compact microcontroller-based architecture.
Figure: Ethernet shield application example
Typical applications include IoT connectivity nodes, embedded web servers, industrial monitoring terminals, and network-enabled robotics systems. This SPI Ethernet shield provides a straightforward path for microcontroller projects to transmit sensor data, host lightweight web interfaces, or communicate with remote cloud services through stable wired networking.
  • W5200 hardwired TCP/IP Ethernet controller with integrated MAC and PHY
  • Supports TCP, UDP, ICMP, IPv4, ARP, IGMP, PPPoE, and Ethernet protocols
  • Eight independent hardware sockets for simultaneous network connections
  • SPI interface (Mode 0 and Mode 3) for simple microcontroller integration
  • Onboard microSD card slot for data storage and web resource hosting
  • 32KB internal buffer memory for transmit and receive operations
  • Supports Wake-on-LAN and power-down energy-saving modes
  • Embedded 10BaseT/100BaseTX Ethernet PHY with auto negotiation
  • Auto MDI/MDIX support for simplified Ethernet cabling
  • Multi‑function LED indicators for link status, speed, and duplex mode
  • 3.3V operation with 5V I/O signal tolerance
  • Embedded web servers
  • IoT gateway nodes
  • Industrial monitoring systems
  • Network-enabled robotics platforms
  • Remote environmental data logging
  • Home automation controllers
  • Educational networking experiments
  • Support Hardwired TCP/IP Protocols: TCP, UDP, ICMP, IPv4 ARP, IGMP, PPPoE, Ethernet
  • Supports 8 independent sockets simultaneously
  • Support Power down mode
  • Support Wake on LAN
  • Support High Speed Serial Peripheral Interface (SPI MODE 0, 3)
  • Internal 32Kbytes Memory for Tx/Rx Buffers
  • 10BaseT/100BaseTX Ethernet PHY embedded
  • Support Auto Negotiation (Full and half duplex, 10 and 100-based )
  • Support Auto MDI/MDIX
  • Support ADSL connection (with support PPPoE Protocol with PAP/CHAP Authentication mode)
  • Multi-function LED outputs (Full/Half duplex, Link, Speed)
  • DFRduino Ethernet Shield for Arduino - W5200 ×1
Jennifer.Roman Sep 09, 2025
excellent quality, will order again.
mohamad.udayana Jul 02, 2024
the best ethetnet shileld for arduino, i try for my project running 1 year more no problem
ines. Sep 16, 2020
Great packaging. Works smoothly
