DFPlayer - A Mini MP3 Player
$5.90
SKU: DFR0299
  • $5.80 3+ items
  • $5.70 5+ items
  • $5.40 10+ items
The Mini MP3 player is a versatile audio module for standalone or embedded projects, supporting high-quality playback, various audio formats, and customization options.
Sing for the moment! DFPlayer Mini MP3 Player is a compact and powerful audio player module that can be used either as a standalone module by directly connecting power, speaker, and buttons, or incorporated into various embedded systems and DIY electronic projects. Meanwhile, DFPlayer mini standalone can be used as a stand-alone module with an attached battery, speaker, and push buttons or used in combination with an Arduino UNO or any other with RX/TX capabilities. Whether you're building your own music player or adding sound effects to your project, the DFPlayer Mini is an ideal choice.
dfrobot mp3 player application
DFRobot MP3 Player Application
DFPlayer Mini supports a maximum sampling rate of 48kHz and 24-bit DAC output, ensuring high-quality audio playback. The module seamlessly integrates hardware decoding for MP3, WAV, and WMA formats, and is also capable of supporting a maximum of 32GB TF card storage with FAT16 and FAT32 file systems through software.
Support for Customization
DFPlayer Mini MP3 player offers extensive support for customization such as hardware and interface modifications, allowing for tailored solutions that suit specific needs and requirements. You can contact our customer service: [email protected] if you have any customization needs.
Selection Guide
MP3 Module Selection Guide
Figure
SKU
DFR0299
DFR0768
DFR0534
Storage
Storage Card Required
128MB
8MB
Sound Channel
Mono
Dual-channel
Mono
Analog U-disk Support
No
Yes
Yes
ADKEY Control Support
Yes
Yes
No
On-board Power Amplifier Support
Yes
Yes
Yes
Audio Format
MP3, WAV, WMA
MP3, WAV, WMA, FLAC, AAC, APE
MP3, WAV
Communication
UART
UART
UART
Operating Voltage
3.3V/5V
3.3V/5V
3.3V/5V
Dimension
20*20mm
23*24.5mm
22*30mm
1. Small size 2. Support IO, serial port and ADKEY control 3. Maximum support 32G of the TF card, suitable for occasions in need of abundant audio files
1. Stereo dual-channel output 2. Support four controlling modes: Arduino, AT command, on-board buttons, and ADKEY 3. On-board 128MB high-speed storage, perfect for occasions in need of storing small numbers of audio files 4. Support the USB cable to copy music 5. Can be used as a sound card for the PC or Raspberry Pi
1. DF-Gravity interface, easy to connect 2. On-board 8MB storage 3.Support the USB cable to copy music 4. Suitable for playing sound effects and prompt sounds
Add to Cart
  • Supports playback switching at the touch of a button
  • Support up to 32GB TF card driver
  • Support MP3, WAV, WMA audio formats
  • High support for 48KHz sample rate and 24-bit DAC output can be output to provide high-quality audio playback effect.
  • Car navigation voice broadcast;
  • Road transport inspectors, toll stations voice prompts;
  • Railway station, bus safety inspection voice prompts;
  • Electricity, communications, financial business hall voice prompts;
  • Vehicle into and out of the channel verify that the voice prompts;
  • The public security border control channel voice prompts;
  • Multi-channel voice alarm or equipment operating guide voice;
  • The electric tourist car safe driving voice notices;
  • Electromechanical equipment failure alarm;
  • Fire alarm voice prompts;
  • The automatic broadcast equipment, regular broadcast.
  • Supported sampling rates (kHz): 8/11.025/12/16/22.05/24/32/44.1/48
  • 24 -bit DAC output, support for dynamic range 90dB, SNR support 85dB
  • Fully supports FAT16, FAT32 file system, maximum support 32G of the TF card, support 32G of U disk, 64M bytes NOR FLASH
  • A variety of control modes, I/O control mode, serial mode, AD button control mode
  • Advertising sound waiting function, the music can be suspended. when advertising is over in the music continue to play
  • Audio data sorted by folder supports up to 100 folders, every folder can hold up to 255 songs
  • 30 level adjustable volume, 6 -level EQ adjustable
  • DFPlayer Mini x1
Halloween trick or treat automata with Voice Recognition module
Projects Halloween trick or treat automata with Voice Recognition module
RoniBandini
Oct 16, 2023
Arduino UNO Project
Projects Arduino UNO Project
RiverTrue
Feb 27, 2023
Blog MP3 Module Selection Guide
Mar 30, 2021
jean marie.MAHOT Aug 25, 2022
perfect to me, I have been using that ones for years with arduino nano
SPYROS.PAPAKONSTANTINOU Aug 22, 2022
Perfect product, fast delivery, Perfect cooperation, I will place orders again
Geoffrey. Feb 06, 2020
One of the best player modules around-- low cost, high bandwidth, programmable (serial line) as well as hard switches. Mini SD card reader too! Use the stereo output for best quality. Use the speaker output for mono convenience. Watch power consumption for high volume speaker output.
