A 5mm Diffused LED Assortment Pack (50pcs) provides a convenient collection of the most commonly used indicator LEDs for electronics prototyping, circuit experiments, and educational projects. The package contains five popular colors—red, blue, green, yellow, and white—each using a diffused lens that softens brightness and distributes light more evenly than clear LEDs. This multi‑color indicator LED kit is well suited for breadboard circuits, signal indicators, and embedded electronics projects. Consistent viewing angles and balanced brightness make the diffused light sources comfortable to observe during extended experimentation and ideal for visual status feedback in hobbyist and laboratory builds.
Note: The current limiting resistor is necessory when using the LEDs. Find calculator at here.
Soft Diffused Light for Comfortable Viewing
Unlike clear‑lens LEDs that concentrate brightness into a narrow beam, each diode in this indicator light assortment uses a diffused epoxy lens to scatter illumination. The result is a softer and more uniform glow that remains visible from multiple angles without harsh glare. Such characteristics make the diffused lighting components suitable for dashboards, status panels, learning kits, and circuit demonstrations where comfortable visibility and consistent brightness across viewing positions are important.
Five Essential Colors for Prototyping
This multi‑color LED assortment includes red, blue, green, yellow, and white emitters—ten pieces of each color. Such variety supports a wide range of circuit signaling needs, including power indicators, status notifications, warning lights, and decorative illumination. Having a ready supply of commonly used colors simplifies rapid hardware prototyping and makes the electronics component pack particularly useful in laboratory testing, DIY electronics builds, and classroom demonstrations.
Convenient Component Pack for Experiments
The 5mm through‑hole LED set is designed for easy integration into breadboards, soldered circuit boards, and quick experimental setups. Standard lead spacing and common electrical characteristics allow straightforward pairing with resistors and microcontroller GPIO outputs. Such practicality makes the component assortment suitable for beginners exploring basic electronics as well as engineers assembling quick proof‑of‑concept circuits or visual indicators on custom boards.
Typical applications include circuit status indicators, electronics education experiments, DIY control panels, and prototype hardware builds. The assorted LED kit provides a practical lighting component selection for electronics hobbyists, laboratories, and STEM learning environments requiring reliable visual feedback elements.
