Soldering Starter Tool Set
$35.95
SKU: KIT0077
  • $35.00 2+ items
  • $34.00 5+ items
  • $32.00 10+ items
The soldering tool set includes a 25W iron, stand, pliers, tweezers, solder tin, and cleaning sponge in a case, ideal for beginners.
Purchase this product and earn 360 reward points, which are tied to VIP membership program. Learn More >
The DFRobot Soldering Starter Tool Set gives you everything you need for most soldering tasks. This set includes a 25-watt pencil iron, cast iron stand, high brightness soler tin, pliers, stainless steel tweezers a a cleaning sponges in a nylon carrying case. DFRobot carefully selected for you this kit for beginners: horseshoe head make it easier to operate; stainless steel tweezers for better clamping; cast iron stand for safer placing soldering. After use, please cool down the soldering iron, drain the water from the sponge as much as possible, and then put back into the toolkit.
  • ​Soldering iron:Power: 220 v / 25 w
  • Welding head: 4 c horseshoe
  • High quality soldering wire
  • Ingredients: tin 62%, the lead 37%, 2%
  • Diameter: 0.8 mm(0.03")
  • Length: 3 m(11.81")
  • ​220 v / 25 w Soldering Iron x1
  • 2% high brightness tin sum of x1
  • High-quality pliers x1
  • Cast iron stand x1
  • Stainless steel tweezers x1
  • Carrying Case x1
Existential Crisis aka Arduino RPG
Blog Existential Crisis aka Arduino RPG
Aug 30, 2016
