WiDo - An Arduino Compatible IoT (internet of thing) Board (Discontinued)
SKU: DFR0321
Discontinued
Wido is an Arduino compatible WIFI IoT Node development board, which integrates with WG1300 WIFI solution. The microcontroller of Wido is ATMEL ATmega32U4.
Wido is compatible with copious amounts of Arduino boards and periphery modules. You can implement it on M2M Sensor Node development, Toys, Gaming, Smart Home Device and many other applications.
Como actualizar el firmware de Wido Node IoT, ejemplo de uso y revisión
(HOW TO UPDATE THE FIRMWARE OF WIDO NODE IOT, EXAMPLE OF USE AND REVISION)
WIDO WiFi IoT Node by dfrobot.com - Install lib and first example
Review of WIDO WiFi IOT Node by dfrobot.com
INTERNET OF THINGS AT YOUR FINGERTIP
TALK TO THE CLOUD. REINVENT THE HOTTEST SMART DEVICE.
DESIGN THE NEXT BIG ONE. SOLVE YOUR UNIQUE PROBLEM.
wido
wido
wido
wido
wido
  • Power Supply range: 5v or 7-12v
  • Arduino Leonardo Compatible
  • Integrate with WG1300 WIFI chip and support 2.4GHz IEEE 802.11 b/g network
  • WIFi and MicroSD driven by SPI port
  • On board 2.4G PCB Antenna
  • Driver pins
  • WIFI Module-D7(IRQ),D5(VBAT),D10(CS),D14(MISO),D15(SCK),D16(MOSI)
  • MicroSD-D4(CS),D14(MISO),D15(SCK),D16(MOSI)
  • User friendly Reset button
  • Dimension: 72 mm x 55 mm(2.83" x 2.17")
    • WiDo x1
