10W Super Bright LED - Warm White with 60 Degrees Lens
$6.90
SKU: FIT0380
  • $6.80 2+ items
  • $6.60 5+ items
  • $6.40 10+ items
10W LED with 500LM brightness and 60-degree lens, ideal for robot projects. Requires heat sink for cooling when used at full power. Various colors available.
This 10W super bright LED can be used as a flash searchlight for your robot projects. It consists of 9 separate LEDs and has a luminance of 500LM. The 60 degrees lens for focusing the light. Comes in various colors.
Warning : If you use the full power, LED will be very hot. Please use Heat Sink to cool it down.
  • Rated Power: 10W
  • Luminance: 500LM
  • Working Voltage : 9V-11V(With Heat Sink); 7.5V-8.5V(Without Heat Sink)
  • Rated Current:  1000mA
  • Color Temperature: 3000K-4000K
  • Angle: 120°
  • Working Temperature: -20°C ~ 60°C
  • Reserving Temperature: -20°C ~ 60°C
  • Size: 29mm*23mm(1.14"*0.91")
  • Weight: 10g
  • Super Bright LED - Warm White with 60 Degree Lens x1
Only 8 Left
