DF Metal Geared 15Kg Standard Servo 270° (DSS-M15S)
$14.90
SKU: SER0038
  • $14.00 5+ items
  • $13.50 10+ items
  • $11.90 50+ items
Heavy-duty servo with 270° rotation, high torque up to 18Kg, stable performance, metal gears, and included steering parts for enhanced functionality.
DSS-M15S is a heavy-duty metal gear standard servo with 270°wide angle, high torque power, improved stability and durability.
Able to take in 6V and deliver a strong torque power of over 15Kg, this tough 270°servo will never let you down when you need it. Tested with high load capacity for 12 hours long, this DSS-M15S servo demonstrates a maximum torque of 18Kg without much vibration or heat.
In addition, we enclose carefully selected steering parts, including an aluminum alloy wheel and a long bracket, to enhance servo performance.
  • Voltage: 4.8-6.8 Volts
  • Torque: 15Kg*cm/17Kg*cm (5.0V/6.8V)
  • Speed: 0.16 sec/60°/0.14 sec/60° (5.0V/6.8V)
  • Free Run Current: 80mA/100mA (5.0V/6.8V)
  • Stall Current: 1.8A/2A (5.0V/6.8V)
  • Standby Current: 4mA/5mA (5.0V/6.8V)
  • Rotation: 270°
  • Wheel Gear: Metal
  • Gear Ratio: 275:1
  • Dimension: 40*20*40.5mm
  • Signal: RC PWM
  • Pulse Range: 500-2500 us
  • Frequency: 50-330Hz(Arduion-compatible)
  • DSS-M15S Servo x1
  • Metal round servo horn x1
  • X servo horn x1
  • long straight servo horn x1
  • Straight servo horn x1
  • M2*8 self tapping screw x5
  • M2 screw washer x5
  • M3*6 screw x1
