Cherokey: A 4WD Basic Robot Building Kit for Arduino
$109.00
SKU: ROB0117
4WD robot kit for Arduino, ideal for beginners. Includes motor driver, sensors, expansion board, and app control. Supports obstacle avoidance and remote control.
Purchase this product and earn 1090 reward points, which are tied to VIP membership program. Learn More >
Cherokey: A 4WD Basic Robot Building Kit for Arduino is a perfect wheeled robot platform to build your own robot and to get started with Arduino. With just a few simple steps of assembling the hardware and tuning the software, and you'll learn all about Arduino, robotics, sensors, Bluetooth communication — as well as obstacle avoidance and remote control. You can also take it further with your own code to take advantage of the ultrasonic sensor, Romeo (All-in-one Bluetooth Microcontroller), IR sensors, and LEDs
Cherokey: A 4WD Basic Robot Building Kit for Arduino is a versatile mobile robot platform compatible with most popular microcontrollers like Arduino Uno, Mega2560, Romeo, Raspberry Pi, ...etc. It embedded the L298P motor driver chip which allows driving two 6-12V DC motors with a maximum 2A current. The integrated 2 way DC motor driver and Xbee & APC220 socket allows you to start your project immediately without the need for an additional motor driver or wireless shield.
Its expansion plate board significantly increases the surface area of Cherokey, allowing you to easily connect a 9g micro servo or a standard sized servo in two different locations so that you can install robotic arm or ultrasonic/ir sensors. The prototyping area makes you convenient to install sensors on the robot. Double-side leaf pads solder prototyping areas in the middle can be soldered with DIP components or SMD components to extend addition function.
Its high-strength aluminum alloy body material also provides flexibility in rapid movement particularly in outdoor grass, gravel, sand or sloped surface. Cherokey: A 4WD Basic Robot Building Kit for Arduino is also suitable for robot competitions and research-related projects.
Thanks to Romeo BLE, this kit can now be played with APP(IOS). Simply download the APP (GoBLE) and enjoy controlling from your IOS device!
  • Controller:  Romeo BLE
  • Microcontroller: ATmega328P
  • Board: Arduino UNO
  • Controller Operating Voltage: 5V
  • Controller Input Voltage (recommended): 7 ~ 12V
  • Ultrasonic Sensor Detecting range: 4cm-3m (3-5m is possible, but depending on situations)
  • Rotation range: 0 - 180
  • Size(Assembled): 220mm*175mm*170mm(8.66"*6.89"*6.69")
  • Weight: 772g(Excluding battery)
  • Maximum Load: 500g
  • TT Geared Motor Specification
Kiyan.Afsari May 08, 2025
The robot is powerful and very easily programmable. The documentations on their wiki pages are very good.
