Wireless Charging Module 5V/1A
$6.90
SKU: DFR0362
  • $6.80 2+ items
  • $6.60 5+ items
  • $6.20 10+ items
This wireless charging module provides 5V@1A power output with 90% transfer efficiency using resonant magnetic coupling, designed for stable energy transfer.
Wireless charging modules uses an electromagnetic field to transfer energy between two objects. This is usually done with a charging station. Energy is sent through an inductive coupling to an electrical device, which can then use that energy to charge batteries or run the device.
This is a new wireless charging module, which could provide 5V@1A (MAX 1.2A) power output. It is using the new technology "resonant magnetic coupling, which will reduce the electricity consumption during power transmission. The transfer efficiency could arrive at 90%. It could meet your most project requests.
5V/300mA also available (Wireless Charging Module 5V/300mA)
I made a full color POV display using SPRESENSE and DotStar LED tape.
  • Stable Power Supply
  • Magnetic coupling resonance technique
  • Insulation Coil
  • Compact Design
  • Operating Voltage (Input): 5V
  • Operating Voltage (Output): 5±6%V@1A (Max: 1.2A)
  • Transmitting Terminal Size: 43mm±2mm(1.69")(Outer diameter)*20mm(0.79")(Inside diameter)*2.3mm(0.09")(Thickness)
  • Receiving Terminal Size: 43mm±2mm(1.69")(Outer diameter)*20mm(0.79")(Inside diameter)*2.3mm(0.09")(Thickness)
  • Operating Distance: 2-10mm (0.08-0.39")
  • Transmitting Module  x1
  • Receiving Module  x1
Model Selection Guide for Wireless Charging Module
Blog Model Selection Guide for Wireless Charging Module
Apr 30, 2021
Making a Wireless Power Supply for the UNIHIKER Single Board Computer
Projects Making a Wireless Power Supply for the UNIHIKER Single Board Computer
Afra
Nov 08, 2024
Dillon.Simeone Jul 01, 2025
They just work! The ones I've been finding on Amazon are trash. This is clean, and straightforward. I'm barely resisting clearing out DFrobot's stock of this.
Yan.Nyein Aug 26, 2021
Haven't used, hopefully will be ok.
