Micro DC Geared Motor 6V 112RPM
$4.90
SKU: FIT0419
  • $4.80 2+ items
  • $4.40 10+ items
Micro DC geared motor with planetary mechanism, ideal for DIY projects needing compact size. Features 6V, 1:171 gear ratio, 110RPM, and low noise.
This is a new micro DC geared motor, using planetary gear mechanism, applicable to the various types of DIY project. Especially the project which has a certain requirements for size. It will be a good partner for you.
Side View Drawing:
Head Drawing:
Tail Drawing:
  • Rated voltage: 6V
  • Gear ratio: 1∶171
  • No-load current: ≤ 45mA
  • Starting torque: 550g·cm(MIN)
  • Output shaft length: 3±0.5mm
  • Insulation resistance: 100V/DC/ 1.0MΩ
  • No-load speed: 110±11RPM
  • Waveform: Sinusoidal waveform
  • Noise:<60db(Ambient noise 30db)
  • Direction:CW
  • Micro DC Geared Motor x1
Make a Mini Disco Ball
Blog Make a Mini Disco Ball
Sep 13, 2016
Ohsoo. Aug 23, 2021
