SPI / I2C Monochrome 60x32 0.5" OLED Display for Arduino
$15.00
SKU: DFR0376
A 0.5" micro OLED display compatible with Arduino and other microcontrollers, featuring 60x32 white pixels, SPI and I2C communication, and low power consumption.
Purchase this product and earn 150 reward points, which are tied to VIP membership program. Learn More >
OCELL is a 0.5" micro OLED display designed for Arduino and other microcontrollers. This micro OLED display is small as the grown-up's fingernail- 0.5" only. It has 450cd/m^2 screen brightness with extremely high contrast and readability; moreover, it contains 60 x 32 independent white OLED pixels that each can be separately controlled by the driver chip. This means you can display any images and words on the screen . Except this, the spontaneous light OLED display does not require a backlight, which greatly reduces the power consumption.
The Oled screen supports SPI (Default setting ) and I2C interface. You could connect it to Ardunio micro directly without doing any PCB layout by yourself, also you could wire it to any other MCUs like STM series , 51 series and so on. It is a good choice for a DIYer to make a interesting stuff by Arduino. Also it is very convenient for a pro-engineer to quickly develop and test a project which need a tiny COOL OLED display.
  • Operating Voltage: 3.3V -5V
  • PCB dimension: 17.8mm x 15.5mm (0.70*0.61")
  • Screen size: 0.5" inch (W*H: 15.30x10.20 mm)
  • Color: Monochrome (white)
  • OLED type: PM -OLEDOLED driver: LD7032
  • Pixels : 60 x 32
  • Contrast: 2000: 1
  • Communication: SPI, I2C
  • Micro Oled driver board x1
  • 0.5“ Oled Display x1
  • 5 Pin header x2
