Holiday Shipping Notice: DFRobot will be out of office Sep 30 – Oct 7 (UTC+8) for the National Day holiday. Shipping resumes Oct 8.
FTDI Basic Breakout 3.3/5V provides a compact USB‑to‑serial interface built around the FT232RL conversion chip, enabling reliable communication between a computer and serial-enabled microcontroller hardware. The breakout board follows the standard FTDI cable pinout widely used by official and compatible Arduino boards, making the module a practical programming and debugging tool for embedded development. A microUSB interface supplies both power and data connectivity, while a clearly labeled 6‑pin header simplifies alignment with common development boards. This USB‑to‑TTL converter board supports both 3.3V and 5V systems through jumper‑selectable output levels, supporting a wide range of microcontroller projects and prototyping tasks.
DTR-Based Auto Reset for Seamless Sketch Uploads
Unlike many USB‑to‑serial adapters that expose the RTS signal, this FT232RL breakout module brings out the DTR pin to support automatic hardware reset during program uploads. The DTR signal enables compatible boards to reset automatically whenever a new sketch is downloaded, removing the need for manual reset timing. Such functionality streamlines firmware uploading and debugging for development boards equipped with a 6‑pin programming header. This design approach is widely adopted across Arduino-compatible hardware ecosystems, including boards using connectors found on Arduino development platforms and wearable-friendly LilyPad boards.
Clear Serial Activity Indicators
This USB serial interface board integrates dedicated TX and RX indicator LEDs that visually display ongoing data transmission. Real‑time LED feedback allows quick verification of communication status during debugging or device configuration. Engineers and makers gain immediate confirmation that serial signals are flowing correctly between the host computer and target microcontroller. Compared with enclosed cable-style adapters, this breakout design exposes diagnostic indicators directly on the PCB, improving troubleshooting efficiency during prototyping, firmware flashing, and serial monitoring workflows.
Flexible Development and Prototyping Integration
Compact PCB layout and clearly marked BLK and GRN orientation pins simplify connection alignment with target controllers. These labels correspond to the ground and DTR wire colors found on standard FTDI cables, reducing connection errors when integrating with compatible boards. Jumper-selectable 3.3V or 5V output further expands compatibility across diverse microcontroller platforms. Such versatility makes this USB‑to‑TTL converter board suitable for embedded system debugging, bootloader flashing, serial console access, and cost‑efficient development setups requiring dependable USB serial communication.
Reliable USB‑to‑serial communication makes this FTDI breakout module valuable across embedded development environments. Applications range from programming Arduino-compatible controllers and wearable electronics to debugging serial communication in custom microcontroller circuits. Visual activity indicators, automatic reset support, and selectable logic voltage allow efficient integration into robotics, IoT prototypes, and electronics education projects that rely on dependable USB‑to‑TTL connectivity.
Basic Parameters
Mar 25, 2021
Well-made board. not tested yet. I use my old USB to TTL Converter (CP210) : https://www.dfrobot.com/product-104.html
