Battery Capacity Indicator
$6.90
SKU: FIT0466
A user-friendly Battery Capacity Indicator with 8 brightness levels and 3.3V-5.5V working voltage, measuring 42x24x8mm. Includes documentation link.
Battery Capacity Indicator provides a simple visual method for monitoring remaining power in battery‑powered electronics. Many embedded projects lack an intuitive way to check energy status, making troubleshooting or power management difficult during development and deployment. This compact battery level display module converts voltage levels into an easy‑to‑read LED bar indicator, enabling rapid assessment of battery condition at a glance. Designed for compatibility with common controller platforms including Arduino systems and other embedded boards, the compact indicator board integrates smoothly into robotics builds, portable electronics, and educational prototypes that require straightforward power monitoring.
Clear Multi‑Level Battery Visualization
An integrated LED display presents battery capacity through eight distinct brightness levels, providing a straightforward visual representation of power status. This LED capacity monitor eliminates the need for complex voltage interpretation, translating electrical measurements into an intuitive bar‑style indicator. Engineers and students gain immediate insight into remaining energy during operation, testing, or demonstrations. The visual feedback system proves especially useful in portable electronics, robotic platforms, and experimental circuits where quick battery evaluation improves reliability and system awareness.
Wide Voltage Compatibility for Embedded Systems
Support for a 3.3V–5.5V working voltage range allows this compact power‑status indicator board to operate with common microcontroller ecosystems and battery configurations. The flexible input range suits lithium battery packs, regulated development boards, and many low‑power electronics platforms. Small physical dimensions allow integration into compact builds while maintaining clear status visibility. Such flexibility makes the battery monitoring module suitable for prototyping environments, educational hardware setups, and embedded electronics where space efficiency and reliable power indication remain important design considerations.
Typical uses include robotics projects, portable electronic devices, DIY battery packs, embedded development boards, and STEM learning platforms that require quick battery monitoring. The compact LED battery indicator supports educational experimentation, maker projects, and practical electronics development where reliable visual feedback about power availability improves debugging efficiency and operational awareness.
  • LED battery capacity indicator with 8 brightness levels
  • Supports operating voltage from 3.3V to 5.5V
  • Compact form factor suitable for embedded electronics integration
  • Provides intuitive visual battery status for rapid diagnostics
  • Suitable for robotics, portable electronics, and educational prototypes
  • Robotics battery monitoring
  • Portable electronics projects
  • DIY battery pack status display
  • Embedded system power diagnostics
  • STEM education electronics experiments
  • Working voltage: 3.3V-5.5V
  • 8 levels of brightness
  • Size: 42*24*8mm/1.65*0.94*0.31 inches
  • Battery Capacity Indicator x1
Only 1 Left
