Waterproof Ultrasonic Distance Sensor (30~500cm)
$16.00
SKU: SEN0208
Waterproof ultrasonic sensor with a sealed emitter, ideal for outdoor use. Operates at 3.0-5.5V, with a range of 20cm-6m and several modes available.
The ultrasonic distance sensor is a high-performance, weatherproof ultrasonic distance sensor designed for reliable operation in challenging environments. It operates on the principle of sonar, emitting high-frequency sound waves and calculating distance based on the time-of-flight of the returning echo. Its key differentiators are a robust, fully-sealed probe separate from the main circuit board, high-precision measurement with temperature compensation, and multiple versatile operating modes to suit a wide range of applications.
Robust Weatherproof Design
The core feature of the ultrasonic distance sensor is its fully enclosed and sealed ultrasonic probe. This design provides significant protection against moisture, dust, and other environmental contaminants, making it ideal for long-term outdoor deployment or in industrial settings where standard sensors would fail. Unlike conventional open-element sensors, it can reliably function in rainy conditions without compromising performance or longevity.
High-Precision Ranging Performance
Engineered for accuracy, the ultrasonic distance sensor provides a resolution of 3mm across its 30cm to 500cm detection range. Crucially, it incorporates built-in temperature compensation. This feature automatically adjusts for variations in the speed of sound caused by temperature fluctuations, ensuring consistent and reliable distance readings across its entire operating range of -20°C to 70°C. The wide 60° measuring angle allows for effective detection of objects within a broad area.
Versatile Operating Modes
To maximize compatibility and ease of integration, the SEN0208 offers several distinct operating modes, allowing it to adapt to different system architectures:
  • PWM Pulse Width Output (Mode 0): The standard trigger/echo mode. A high pulse on the trigger pin initiates a measurement, and the sensor returns a pulse on the echo pin whose duration is proportional to the measured distance. This is ideal for direct connection to microcontrollers.
  • UART Automatic Output (Mode 1): In this mode, the sensor autonomously performs a measurement every 100ms and streams the distance data via its UART TX pin. This simplifies implementation by offloading timing control from the host processor.
  • UART Controlled Output (Mode 2): This mode provides on-demand measurement via UART. The host controller sends a trigger command to the sensor's RX pin, and the sensor responds with a single distance measurement. This allows for precise control over when measurements occur.
  • Switch Output (Mode 3): This mode transforms the sensor into a non-contact proximity switch. When an object is detected within a pre-set distance threshold (default 1.5m), the output pin goes to a high state. This is perfect for simple presence detection applications without needing a microcontroller to interpret data.
  • Note: This Version 2.0 model is a significant upgrade to the previous SR04T model. Key enhancements include a wider operating voltage range of 3.3V to 5V (compared to the 5V-only SR04T), providing greater compatibility. Additionally, it features multiple selectable operating modes for superior flexibility and versatility in various applications.
    • Robotics and Autonomous Vehicles: For robust obstacle avoidance and navigation in all weather conditions.
    • Industrial Automation: For liquid level sensing in tanks, material height monitoring in hoppers, and object detection on production lines.
    • Automotive Systems: As a durable sensor for parking assist and vehicle detection systems.
    • Security and Monitoring: For reliable presence detection in outdoor security systems or public spaces.
    • Smart City Projects: For applications like monitoring fill levels in public waste bins or detecting vehicle presence in smart parking lots.
    • Working voltage: DC 3.3-5V
    • Detection range: 30cm~500cm
    • Accuracy: ±(1+S*0.5%)
    • Measurement angle: 60°
    • Quiet current: 8mA
    • Working current: 40mA
    • Working frequency: 40KHz
    • Resolution: 3mm
    • Temperature compensation: Yes
    • Working temperature: -20 ~ 70°C
    • PCB Size: 42 * 29 * 12 mm
    • Waterproof Ultrasonic Distance Sensor x1
    Ivan.Pavelic Nov 27, 2025
    Good for detecting range.
    Out Of Stock
