Micro Metal Geared Stepper Motor (12V 0.6kg.cm)
$5.20
SKU: FIT0503
Miniature stepper motor with 100:1 gear box for torque. Voltage: 5-12V. Ideal for 3D printers needing precise rotation. Limit current to avoid damage.
Purchase this product and earn 52 reward points, which are tied to VIP membership program. Learn More >
This is a miniature stepper motor with 100:1 metal reduction gear box for enhanced torque. It has a voltage input range of 5 - 12V DC. This product is suitable for the 3D printers and applications which require precise rotation control.
Note: Please limit the motor current, or overlarge current will burn the motor.
  • Stepper Motor:
    • Coil resistance: 30Ω±10%
    • NO. Of Phases: 2 PHASES
    • Step Angle: 18° / Step
    • MAX.Starting Frequency: 900PPS min
    • MAX.Slewing Frequency: 1200 PPS min
    • Pull IN Torque: 6gf-cm min
    • Lead Out Torque: 10gf-cm max
  • Stepper Motor with Gear Box:
    • Step Angle: 18/100° / Step
    • Pull IN Torque: 0.5Kgf-cm min
    • Lead Out Torque: 0.8Kgf-cm max
  • Cable Length: 15cm
  • Weight: 14g
  • Micro Metal Geared Stepper Motor (12V 0.6kg.cm) x1
