0.96 Inch OLED Display Module For Raspberry Pi
$23.90
SKU: DFR0413
Portable 0.96" OLED display for Raspberry Pi projects, featuring SSD1306 controller, SPI communication, high contrast, wide viewing angle, and low power consumption.
Purchase this product and earn 169 reward points, which are tied to VIP membership program. Learn More >
Sometimes your Raspberry Pi projects require a display to output system information, e.g. system status, temperature, IP address, etc. Having a full sized display attached is inconvenient if you want your project to be portable. Use this small OLED to output your required information and keep your product in a nice portable configuration. The display is a 0.96" 128 x 64 px OLED. The controller is a SSD1306 and communicates via 4-wire SPI. The display also includes a built in backlight and is high contrast with an extremely wide viewing angle.
  • Operating Voltage: 3.3V (1.6~3.6V)
  • Continuous Current: 12.25uA
  • Maximum Current: 100uA
  • Ultra low power supply
  • Internal DC/DC voltage converter
  • SPI driver support , AT 64MHz[TYP] 125MHZ[OB]
  • FP frequency: 64fps[TYP] 368fps[OB]
  • Dimension: 370*300mm/14.6*11.8 inches
  • 0.96 Inch OLED Display Module For Raspberry Pi x1
Only 9 Left
