Metal DC Geared Motor - 6V 20RPM 7.5Kg.cm
$9.90
SKU: FIT0495-B
Compact metal DC geared motor with 362:1 reduction, delivering up to 7.5 kg.cm torque. Operates at 6V, 20 RPM, and weighs 74g. Durable and stable design.
This is a metal DC geared motor, 362:1 metal reducer. It has a small size and large torque. The maximum torque could arrive 7.5 kg.cm. It is stable and durable!
Romeo BLE Application connection - DFRobot
Metal DC Geared Motor - DFRobot dimension
  • Rated Voltage: 6 V
  • Operating Voltage Range 2~7.5V
  • Gear reduction ratio: 362:1
  • Gearbox length: 27 mm
  • "D" shape shaft diameter: 4 mm
  • No-load speed: 20 RPM @ 6V
  • No-load current: 50 mA
  • Locked-rotor torque: 7.5 Kg.cm
  • Locked-rotor current: 0.6 A
  • Operating Temperature: -20~60℃
  • Weight: 74 g
  • Metal DC Geared Motor - 6V 20RPM 7.5Kg.cm x1
