  This is a metal DC geared motor, 362:1 metal reducer. It has a small size and large torque. The maximum torque could arrive 7.5 kg.cm. It is stable and durable!
  Rated Voltage: 		6 V
Operating Voltage Range 2~7.5V
Gear reduction ratio: 362:1Gearbox length:		27 mm
"D" shape shaft diameter: 4 mm
No-load speed: 		20 RPM @ 6V
No-load current: 	50 mA
Locked-rotor torque: 7.5 Kg.cm
Locked-rotor current: 	0.6 A
Operating Temperature:	-20~60℃
Weight: 		74 g
  Metal DC Geared Motor - 6V 20RPM 7.5Kg.cm   x1
