Metal DC Geared Motor - 6V 73RPM 2.5Kg.cm
$9.90
SKU: FIT0495-E
Metal DC geared motor with 99:1 reduction, small size, large torque (2.5 kg.cm max), stable and durable. Rated 6V, 73 RPM, weighs 72g.
This is a metal DC geared motor, 99:1 metal reducer. It has a small size and large torque. The maximum torque could arrive 2.5 kg.cm. It is stable and durable!
Romeo BLE Application connection - DFRobot
Metal DC Geared Motor - DFRobot dimension
  • Rated Voltage: 6 V
  • Operating Voltage Range 2~7.5V
  • Gear reduction ratio: 99:1
  • Gearbox length: 23 mm
  • "D" shape shaft diameter: 4 mm
  • No-load speed: 73 RPM @ 6V
  • No-load current: 50 mA
  • Locked-rotor torque: 2.5 Kg.cm
  • Locked-rotor current: 0.6 A
  • Operating Temperature: -20~60℃
  • Weight: 72 g
  • Metal DC Geared Motor - 6V 73 RPM 10Kg.cm x1
  • Only 9 Left
