Metal DC Geared Motor - 6V 97RPM 1.9Kg.cm
$9.90
SKU: FIT0495-F
Metal DC geared motor with 75:1 reduction, small size, large torque (1.9 kg.cm). Rated voltage 6V, operates 2-7.5V, stable, durable, 74g.
This is a metal DC geared motor, 75:1 metal reducer. It has a small size and large torque. The maximum torque could arrive 1.9 kg.cm. It is stable and durable!
Romeo BLE Application connection - DFRobot
Metal DC Geared Motor - DFRobot dimension
  • Rated Voltage: 6 V
  • Operating Voltage Range 2~7.5V
  • Gear reduction ratio: 75:1
  • Gearbox length: 23 mm
  • "D" shape shaft diameter: 4 mm
  • No-load speed: 97 RPM @ 6V
  • No-load current: 50 mA
  • Locked-rotor torque: 1.9 Kg.cm
  • Locked-rotor current: 0.6 A
  • Operating Temperature: -20~60℃
  • Weight: 74 g
  • Metal DC Geared Motor - 6V 15RPM 10Kg.cm x1
  • Only 17 Left
