Metal DC Geared Motor - 6V 162RPM 1.2Kg.cm
$9.90
SKU: FIT0495-G
Compact metal DC geared motor features a 45:1 reduction ratio, 1.2 kg.cm torque, and operates at 6V. Durable with a 21mm gearbox and 15 RPM speed.
Metal DC Geared Motor – 6V 15RPM integrates a compact brushed DC motor with a durable 45:1 metal gearbox to deliver stable low‑speed motion and reliable torque in space‑constrained robotics builds. The small gearmotor provides smooth rotational control while maintaining strong mechanical output for lightweight mobile platforms, smart mechanisms, and automated prototypes. A hardened metal reduction system improves durability under repeated load conditions, making this miniature drive unit suitable for educational robots, motion experiments, and embedded electromechanical systems that require dependable torque at low rotational speeds.
High Torque from a Compact Gear Reduction System
A precision 45:1 metal gearbox multiplies motor output to generate strong rotational force despite the miniature footprint. This compact geared actuator delivers up to 1.2 Kg.cm locked‑rotor torque while maintaining a controlled 15 RPM no‑load speed at 6 V. Such performance enables efficient motion control for wheeled robots, small robotic arms, automatic mechanisms, and experimental electromechanical assemblies requiring stable low‑speed output and dependable torque transmission.
Durable All‑Metal Gear Train
An internal metal gear reducer enhances durability and wear resistance compared with plastic gear alternatives. The reinforced gear transmission improves long‑term mechanical stability during continuous operation or repetitive load cycles. This miniature gearbox motor therefore suits engineering prototypes, robotics platforms, and classroom mechanical demonstrations where reliability and mechanical endurance are essential.
Romeo BLE Application connection - DFRobot
Figure: Motor connection example
Compact Mechanical Form for Robotics Integration
A short 21 mm gearbox and 4 mm “D”‑shaped output shaft simplify mechanical coupling with wheels, hubs, and custom drive components. The compact form factor allows installation in small robotic chassis, mobile platforms, and prototype mechanisms where installation space is limited. The D‑shaft profile also improves coupling stability and reduces slippage when connected to mechanical transmission parts.
Metal DC Geared Motor - DFRobot dimension
Figure: Motor dimensions
This miniature DC gearmotor serves as a reliable motion component for robotics development, small automation devices, educational mechanical experiments, and compact drive systems. Strong torque output, durable metal gears, and a small installation footprint make the motor module well suited for mobile robots, DIY engineering builds, and experimental motion control platforms.
  • Compact DC gearmotor with 45:1 metal reduction gearbox
  • High torque output up to 1.2 Kg.cm locked‑rotor torque
  • Low‑speed rotation: 15 RPM at 6 V
  • Durable metal gear train for improved lifespan
  • 4 mm D‑shaped shaft for secure mechanical coupling
  • Wide operating voltage range: 2–7.5 V
  • Suitable for robotics, mechanical prototypes, and educational projects
  • Small mobile robots
  • DIY robotics platforms
  • Educational mechanical experiments
  • Smart automation mechanisms
  • Prototype electromechanical systems
  • Compact drive modules for engineering projects
  • Rated Voltage: 6 V
  • Operating Voltage Range 2~7.5V
  • Gear reduction ratio: 45:1
  • Gearbox length: 21 mm
  • "D" shape shaft diameter: 4 mm
  • No-load speed: 15 RPM @ 6V
  • No-load current: 50 mA
  • Locked-rotor torque: 1.2 Kg.cm
  • Locked-rotor current: 0.6 A
  • Operating Temperature: -20~60℃
  • Weight: 68 g
  • Metal DC Geared Motor - 6V 15RPM 10Kg.cm x1
  • Only 13 Left
