The Gravity 4Pin I2C/UART sensor cable is a standard Gravity series 4-Pin cable with 30cm length. One side is PH2.0-4p connector and the other side is XH2.54 DuPont port. it is compatible with standard breadboard pin pitch, which makes it easy to make a DIY application.
The cable uses the colorcoded design to distinguish between the positive and negative power supply, I2C SDA SCL, UART RX TX. Easy to recognize and use.
Sep 20, 2025
Good service and fast shipping
Aug 27, 2025
Sweet little extensions.
