Gravity: 4Pin I2C/UART Sensor Cable (10PCS)
$6.00
SKU: FIT0513
  • $5.70 5+ items
  • $5.40 10+ items
  • $4.80 50+ items
The 4Pin I2C/UART sensor cable is 30cm long, features PH2.0-4p and XH2.54 connectors, color-coded for easy identification, and handles 50V/1000mA. Comes in a pack of 10.
Purchase this product and earn 60 reward points, which are tied to VIP membership program. Learn More >
The Gravity 4Pin I2C/UART sensor cable is a standard Gravity series 4-Pin cable with 30cm length. One side is PH2.0-4p connector and the other side is XH2.54 DuPont port. it is compatible with standard breadboard pin pitch, which makes it easy to make a DIY application.
The cable uses the colorcoded design to distinguish between the positive and negative power supply, I2C SDA SCL, UART RX TX. Easy to recognize and use.
  • Withstand Voltage: 50V
  • Withstand Current: 1000mA
  • Length: 30cm
  • I2C/UART Pin Order: Red --- VCC
  • Black --- GND
  • Blue --- SCL/RX
  • Green --- SDA/TX
  • Gravity 4Pin I2C/UART Sensor Cable x10
  • Review
    Aunuun Jeffry.Mahbuubi Sep 20, 2025
    Good service and fast shipping
    Simon.Holden Aug 27, 2025
    Sweet little extensions.
