FireBeetle ESP8266 IoT Microcontroller (Supports Wi-Fi)
$7.50
SKU: DFR0489
  • $7.20 5+ items
  • $6.90 10+ items
  • $6.40 50+ items
The FireBeetle ESP8266 is a low-power IoT development board with WiFi, multiple interfaces, and Arduino compatibility, featuring a 32-bit MCU and 10-bit ADC.
DFRobot FireBeetle is a series of low-power-consumption development hardware designed for Internet of Things (IoT). Firebeetle ESP8266 is a development board integrated with IoT WiFi, TCP/IP, 32-bit MCU, 10-bit ADC, and multiple interfaces such as HSPI, UART, PWM, I2C, and I2S. In DTIM10, the full power consumption to maintain a WiFi connection reached 1.2mW. Equipped with 16MB outer SPI flash memory, ESP8266 is available for programs and firmware storage.
Compatible with Arduino programming enables Firebeetle ESP8266 to lower the barrier of programming. The operator can implement Arduino programming codes directly onto ESP8266 to reduce the difficulty of operating and increase the stability of the esp8266 board.
In the programming stage, Firebeetle Board-ESP8266 supports RTOS SDK in Linux, Arduino IDE, and Micropython.
Tech Note 072 - ESP8266 and MAX30100 blood oximetry and heart-rate sensor display
NOTE: There still remain some bugs to be detected and fixed by developers. In some cases, some peripherals may not work perfectly by embedding Arduino sample codes in ESP8266.  Much more functions implemented in Arduino are still under development and improvement. An alternative way is to change development tools such as RTOS and MicroPython towards a more operating-friendly experience in some conditions.
  • Compatible with FireBeetle series
  • Compatible with Arduino programing
  • Built-in 32-bit Tensilica L106 MCU and 10-bit ADC
  • Support RTOS SDK in Linux, Arduino IDE and Micropython.
  • Support IEEE802.11 b/g/n WiFi (2.4 GHz~2.5 GHz)
  • Support TCP / IP
  • Support Lithium Battery (The Maximum charge current: 500mA)
  • Support Low Power Consumption
  • Support OTA Updating
  • Support STA/AP/STA+AP
  • Operating Voltage: 3.3V
  • Input Voltage (limits): 3.3~5V (Lithium Battery:3.7V & USB:5V)
  • Microcontroller: Tensilica L106 (32-bit MCU)
  • Clock Speed: 80MHz (Maximum: 160MHz)
  • SRAM:50KB
  • External Flash Memory: 16MB
  • DC Current in the Low-Power-Consumption: 46uA
  • Average Operating Current: 80mA
  • Maximum Discharging Current: 600mA (LDO-3.3 Output)
  • Maximum Charging Current: 500mA
  • Digital Pin x10
  • Analog Pin x1
  • SPI interface x1
  • I2C interface x1
  • IR interface x1
  • I2S interface x1
  • Interface: XH2.54mm Pin (No soldering default)
  • In Combination of Wi-Fi MAC/ BB/RF/PA/LNA
  • WiFi: IEEE802.11 b/g/n (2.4 GHz~2.5 GHz), not support 5GHz WiFi
  • Dimension: 58 × 29(mm)
  • Operating Temperature: -10℃~+55℃
  • Mounting Hole Dimension: 53 x 24(mm)
  • Weight: 24g
  • FireBeetle Board-ESP8266 ×1
  • 18pin-2.54mm ×2
  • 18pin-2.54mm Female Holder ×2
    FireBeetle V1 vs V2 (ESP32/ESP8266/Arduino) Development Board Selection Guide
    Blog FireBeetle V1 vs V2 (ESP32/ESP8266/Arduino) Development Board Selection Guide
    Jun 08, 2025
    MicroPython Tutorials Overview
    Blog MicroPython Tutorials Overview
    Jul 14, 2017
    ESP8266 Project: Desktop Weather Station With WIFI
    Blog ESP8266 Project: Desktop Weather Station With WIFI
    Nov 13, 2017
    Comparisons between FireBeetle ESP32, ESP8266, ESP32 C6, and ESP32 S3
    Blog Comparisons between FireBeetle ESP32, ESP8266, ESP32 C6, and ESP32 S3
    Sep 25, 2023
    RGB HexMatrix | IOT Clock
    Projects RGB HexMatrix | IOT Clock
    Mukesh Sankhla
    Feb 12, 2021
    Maksym.Odintsov Aug 14, 2025
    Bought it's by mistake one year ago but now have new project. And already have microcontroller. Cooool
    wajdi. Oct 21, 2022
    Very good as description
    dancy.dai Sep 09, 2021
    good!!!
