32x16 RGB LED Matrix Panel (6mm pitch)
$19.90
SKU: DFR0471
32x16 RGB LED Matrix Panel with 512 LEDs, controllable via 13 GPIOs. Suitable for indoor/outdoor use, requiring 5V@2A power. Supports cascading with high-performance controllers.
City night is always beautiful. She is just like a charming girl, showing her beauty every time. The colorful light is jewelry, dotted on her dress.
This is a 32x16 RGB LED Matrix Panel, it has 512 full-color RGB LEDs in all. Each LED can be independently addressed and controlled. It requires at least 13 digital GPIOs to control the LED matrix. The led matrix has 2 IDC connectors (DATA_IN, DATA_OUT) on the back, you can cascade multiple panels and make a huge screen together. BUT Arduino doesn’t support this function, its speed is not enough to multiple panel.
What's more, it is a high brightness, long life, no pollution, pure color LED display module. It can be used both indoor and outdoor, safety and stability, the module can not be mutually extrusion deformation, also can be used normally in harsh environment.
Note: This panel needs a 5V@2A power supply. And if you connect 4 or more screen, it needs a high performance controller, such as Mega 2560, Raspberry. .etc.
  • Operating voltage: DC 5V
  • Average power consumption: <500W/㎡
  • Maxim Power Consumption: <1000w/㎡
  • Pixel: 32x16=512
  • Level of viewing Angle: ≧160°
  • Control mode: Synchronous control
  • Drive mode: 1/8 scan rate
  • Repetition frequency: ≧60Hz
  • White Balance Brightness: ≧1200cd/㎡
  • Refresh frequency : ≧300Hz
  • MTTF: ≧5000 hours
  • Service Life: 75000~100000 hours
  • Pixel pitch: 6mm
  • Dimension: 192mm*96mm/7.56*3.78 inches
  • Thickness: 11mm
  • 32x16 RGB LED Matrix Panel (6mm pitch) x1
  • IDC to XH2.54 cable x1
  • IDC to IDC cable x1
  • Power supply cable x1
    How to Make a Bluetooth Music Player
    Blog How to Make a Bluetooth Music Player
    Jul 06, 2018
