64x64 RGB LED Matrix Panel (3mm pitch)
$59.00
SKU: DFR0499
64x64 RGB LED Matrix Panel with 4096 LEDs, requiring 13 GPIOs. Ideal for Mega 2560, Raspberry Pi. High brightness, durable, suitable for indoor/outdoor use.
City night is always beautiful. She is just like a charming girl, showing her beauty every time. The colorful light is jewelry, dotted on her dress.
This is a 64x64 RGB LED Matrix Panel, it has 4096 full-color RGB LEDs in all. Each LED can be independently addressed and controlled. It requires at least 13 digital GPIOs to control the LED matrix. So the UNO board won’t be a good choice in this application, recommended Mega 2560, Raspberry Pi and the other kinds of microcontroller with large RAM and high speed.
The led matrix has 2 IDC connectors (DATA_IN, DATA_OUT) on the back, you can cascade multiple panels and make a huge screen together. BUT Arduino doesn’t support this function, its speed is not enough to multiple panel.
What's more, it is a high brightness, long life, no pollution, pure color LED display module. It can be used both indoor and outdoor, safety and stability, the module can not be mutually extrusion deformation, also can be used normally in harsh environment.
Note: This panel needs a 5V@5A power supply.
  • Operating voltage: DC 5V
  • Average power consumption: <500W/㎡
  • Maxim Power Consumption: <1000w/㎡
  • Pixel: 64x64=4096
  • Level of viewing Angle: ≧160°
  • Control mode: Synchronous control
  • Drive mode: 1/16 scan rate
  • Repetition frequency: ≧60Hz
  • White Balance Brightness: ≧1200cd/㎡
  • Refresh frequency : ≧300Hz
  • MTTF: ≧5000 hours
  • Service Life: 75000~100000 hours
  • Pixel pitch: 3mm
  • Dimension: 190 * 190 * 14.5 mm / 7.48 * 7.48 * 0.57 inches
  • Thickness: 11mm
  • 64x64 RGB LED Matrix Panel (3mm pitch) x1
  • IDC to XH2.54 cable x1
  • IDC to IDC cable x1
  • Power supply cable x1
  • FAQ
    Notify Me Notify me when available
