FireBeetle 328P Low-Power Arduino Board (BLE 4.1)
$18.90
SKU: DFR0492
  • $17.95 5+ items
  • $17.05 10+ items
  • $15.15 50+ items
Low-power microcontroller for IoT with Bluetooth 4.1. Supports Arduino IDE and various Bluetooth functions, offering efficient, versatile connectivity options.
The FireBeetle Board-328P with BLE4.1 is a low-power consumption microcontroller featuring an ATmega328P processor and a DIALOG BLE 4.1 chip. It operates at 3.3V (8MHz) and is compatible with Arduino Pro/Pro Mini. The board supports both BLE central and peripheral modes, multi-device cascade (up to 4 devices), and P2P wireless programming. Key low-power features include a 25µA standby current and dual interrupt wakeup capabilities. It has an onboard lithium battery charging circuit (400mA max) and can be powered by a 3.7V Li-ion battery or 3.7V-5.5V via VCC. Peripherals include 14 digital I/O, 6 analog inputs, SPI, I2C, and UART.
FireBeetle Board-328P with BLE4.1 Features
FireBeetle BLE 4.1 is compatible with the Bluno series (BLE 4.0) and performs much better. FireBeetle Board-328P with BLE4.1 is equipped with a more stable DIALOG Bluetooth 4.1 chip, supporting a maximum 4Kbyte/s transmission rate and low power consumption (25uA POWER DOWN). It can be directly applied to low power consumption application such as wearable and intelligent tools and so on.
FireBeetle Board-328P with BLE4.1 Dimension
It also supports bluetooth 4.1 multiple devices, KISS connections (approach connections) and is compatible with the Bluno series. Its connection can be realized by holding the host BOOT and moving to the target peripheral device.
FireBeetle Board-328P with BLE4.1 Low Power Management
Arduino GSM Module Poultry Temperature Project
  • Support Arduino IDE program
  • Support BLE 4.1 central and peripheral switch
  • Support Bluetooth serial port data transmit
  • Support Bluetooth peer to peer (P2P) wireless programming
  • Support Bluetooth 4.1 multiple device cascade (maximum:4)
  • Support Arduino Bluetooth library (support multiple Bluetooth connections)
  • Support low power consumption Bluetooth (standby current: 25uA; enabled interrupt current: 70uA)
  • Double interruption to wake up:
  • BLE4.1 awake Atmage328P by D2 (high level awake)
  • Atmage328P awake BLE4.1 by D3 (low level awake)
  • Support KISS connection (approach connection)
  • Support Bluetooth firmware update
  • Support USB charge
  • Support lithium battery power supply
  • Equipped with status LEDs
  • Processor: ATMEGA328P
  • Bootloader: Arduino Pro or Pro Mini, ATmega328 (3.3V, 8MHz)
  • Operating Current: 3.3V
  • VCC I/O Voltage: 3.7V~5.5V
  • Lithium Battery Voltage: 3.7V
  • Support maximum 4Kbyte/s transmission rate (more device, lower rate)
  • Support low power consumption: 25uA (POWER DOWN); 70uA (enabled interruption)
  • Support maximum discharge current: 600mA (LDO-3.3V OUTPUT)
  • Support maximum charge current: 400Ma
  • Digital Interfaces: 14
  • Analog Interfaces: 6
  • SPI: 1
  • I2C: 1
  • UART: 1
  • LED_BUILTIN: D13
  • Interface Mode: 2.54mm (Pin/Female header), soldering free in default
  • Dimension: 58 * 29 mm/ 2.28 * 1.14 inches
  • FireBeetle Board-328P with BLE4.1 x1
  • 18 pin-2.54mm x2
  • 18 female header-2.54mm x2
    Portable/Wearable Health Monitoring IoT System
    Blog Portable/Wearable Health Monitoring IoT System
    Aug 17, 2018
    Comparisons between FireBeetle ESP32, ESP8266, ESP32 C6, and ESP32 S3
    Blog Comparisons between FireBeetle ESP32, ESP8266, ESP32 C6, and ESP32 S3
    Sep 25, 2023
    HYUNDONG.SHIN Aug 07, 2022
    I made a human detector using a low-power Bluetooth board. Lithium polymer batteries will be used.
    Only 19 Left
