DFRduino M0 Mainboard (Arduino Compatible)
$9.90
SKU: DFR0392
32-bit Arduino-compatible microcontroller with ARM Cortex-M0 core, supports 5V logic, features 31 digital and 6 analog pins, and includes HiFi audio playback.
DFRduino M0 Mainboard is a 32‑bit Arduino compatible controller built around a Nuvoton ARM Cortex‑M0 microcontroller while maintaining full 5V logic compatibility. This 32‑bit development board bridges the gap between traditional UNO‑class controllers and higher‑cost mega‑style boards by delivering stronger processing performance, expanded GPIO resources, and seamless compatibility with familiar Arduino Leonardo pin mappings. The embedded ARM architecture running at 72 MHz enables significantly faster execution for robotics, automation, and embedded control tasks while preserving the convenient development workflow widely used in maker and educational environments.
32‑Bit ARM Cortex‑M0 Performance with 5V Logic
This ARM‑based microcontroller board integrates the Nuvoton NUC123ZD4AN0 processor operating at 72 MHz, providing a substantial performance upgrade compared with common 8‑bit development boards. Native 5V logic support allows direct connection with many legacy shields, sensors, and peripherals without voltage level conversion. The combination of a 32‑bit processing core and standard logic compatibility creates a practical solution for embedded control systems requiring improved computational capability while retaining compatibility with widely available Arduino‑ecosystem hardware.
Expanded I/O Resources and Flexible Interfaces
This 32‑bit controller platform provides 31 digital I/O pins with partial multiplexing and 6 analog inputs, enabling complex projects requiring numerous sensors or actuators. Multiple communication interfaces simplify system integration, including SPI, I2C, USB serial communication, and two hardware UART ports. Integrated XBee interface support through Serial1 allows convenient wireless communication integration, making this embedded control board suitable for robotics platforms, wireless monitoring nodes, and multi‑sensor embedded systems.
Integrated IIS Audio Interface for HiFi Playback
An onboard IIS interface expands functionality beyond traditional microcontroller control tasks by enabling digital audio playback capabilities. When paired with a professional IIS audio chip, this embedded development board supports playback of WAV audio files with high‑fidelity output. Such capability allows creation of interactive devices, smart voice feedback systems, educational demonstration tools, and embedded multimedia applications that require reliable microcontroller control alongside audio output functionality.
This ARM Cortex‑M0 development platform serves robotics control systems, embedded automation projects, wireless communication nodes, and interactive electronic prototypes. Rich I/O resources, integrated communication interfaces, and audio playback capability make this microcontroller board suitable for makers, research laboratories, and STEM Education environments requiring a powerful yet accessible 32‑bit controller compatible with familiar Arduino development workflows.
  • 32‑bit ARM Cortex‑M0 microcontroller running at 72 MHz
  • Full 5V logic compatibility for easy integration with common modules and shields
  • 31 digital I/O pins and 6 analog input pins
  • Arduino Leonardo pin mapping compatibility
  • Integrated USB serial communication interface
  • Two hardware serial ports for multi‑device communication
  • SPI and I2C communication interfaces
  • Dedicated XBee interface through Serial1
  • Integrated IIS interface supporting WAV audio playback
  • High‑performance embedded control suitable for robotics and IoT projects
  • Robotics controllers and mobile robot platforms
  • Embedded automation systems
  • Wireless communication projects using XBee modules
  • Interactive electronic installations with audio playback
  • Educational microcontroller laboratories
  • Sensor data acquisition systems
  • IoT prototyping platforms
  • Microcontrollers: Nuvoton NUC123ZD4AN0 (Cortex M0)
  • Clock Speed: 72MHz
  • Operating Voltage: 5V
  • Recommended Input Voltage: 7-12V
  • Limit input voltage: 6-20V
  • Digital I/O Pins: 31
  • Analog input Pins: 6
  • External Interrupt: 4
  • SRAM: 20K
  • Flash: 68K (12 KB of which is allocated to bootloader, 55K used by the user code area, 1K used by EEPROM)
  • EEPROM: 1K
  • SPI: 1 port (D14, D15, D16)
  • I2C: 1 port (D2, D3)
  • USB serial port: 1 (Serial)
  • Physical serial port: 2 (Serial1, Serial2)
      Serial1 0 (Rx1) and 1 (Tx1)
      Serial2 24 (Rx2) and 25 (Tx2)
  • Xbee interface: 1 (Serial1)
  • Size: 68 x 53 mm/ 2.68 x 2.09”
  • Weight: 30g
  • DFRduino M0 Mainboard (Arduino Compatible) ×1
