LoRa MESH Radio Module - 433MHz
$39.90
SKU: TEL0114
LoRa MESH Radio Module offers long-range, low-power communication with embedded MESH protocols, supporting flexible configuration via software or microcontroller.
LoRa MESH Radio Module (433MHz) is a long‑range wireless communication module designed for distributed ad‑hoc networking and low‑power IoT connectivity. The RF transceiver integrates LoRa spread‑spectrum modulation with embedded MESH MANET networking protocols, enabling automatic node discovery and multi‑hop communication without additional firmware development. This long‑distance wireless networking module supports transparent serial transmission and reliable packet delivery through built‑in CRC error correction and frequency‑hopping techniques. Flexible serial configuration allows seamless integration with common development platforms such as Arduino controllers and embedded systems, making the radio unit suitable for rapid deployment in industrial telemetry, remote sensing networks, and distributed robotics communication.
Built‑in MESH MANET Networking
This LoRa networking module integrates a distributed MESH MANET protocol that automatically forms ad‑hoc wireless networks between multiple nodes. Each node can relay data across the network, enabling multi‑hop communication without manual routing configuration. Embedded protocol management eliminates the need for secondary development, allowing rapid deployment of large‑scale wireless sensor networks. Multi‑handshake data confirmation mechanisms improve transmission reliability and maintain stable communication between nodes operating across extended distances.
Long‑Range Communication with High Sensitivity
The long‑distance RF communication board uses LoRa spread‑spectrum technology combined with frequency hopping and forward error correction to maintain strong signal integrity in complex environments. Receiver sensitivity reaches −148dBm while transmit power can reach up to +20dBm, delivering reliable communication across open‑area distances of approximately 2–3 km. These capabilities provide strong resistance to interference and maintain low packet error rates, making the wireless transceiver suitable for outdoor monitoring networks and industrial data links.
Flexible Configuration and Communication Modes
This embedded wireless transceiver supports transparent transmission mode, API communication mode, and AT command configuration. Module parameters can be adjusted through host microcontrollers or via PC configuration tools. Parameter setup is conveniently performed using a USB to TTL Converter, while direct hardware integration is simplified through compatibility with expansion hardware such as the Gravity IO Expansion Shield. TTL‑level serial communication and adjustable transmission power provide flexible adaptation to diverse embedded system requirements.
Low‑Power Operation and Reliable System Protection
This micro‑power wireless radio board operates within a wide voltage range and features adjustable transmission power levels to balance communication distance and energy consumption. Support for serial wake‑up and air‑wake AUX signals allows connected host systems to remain in low‑power standby until communication activity occurs. A built‑in watchdog ensures long‑term stable operation, while CAD LoRa signal detection helps prevent accidental wake events in noisy RF environments.
Typical applications include wireless sensor networks, industrial telemetry systems, robotics communication links, remote environmental monitoring, and distributed IoT infrastructure where stable long‑range connectivity and scalable mesh networking are required.
  • Frequency Range: 433/490MHz (Sx1278)
  • Based on LoRa modulation techniques
  • Half‑duplex communication with serial transparent data transmission
  • Embedded distributed MESH MANET networking protocol
  • Multiple handshake confirmations for reliable data transmission
  • Operating voltage range 3.4–5.5V (customizable 2.1–3.6V)
  • Micro‑power transmission, standard 100mW with 7 adjustable power levels
  • Receiver sensitivity up to −148dBm and transmit power up to +20dBm
  • Forward error correction and frequency hopping for strong anti‑interference capability
  • Serial wake‑up support for immediate data transmission
  • AUX signal air‑wake capability for external device activation
  • CAD detection for LoRa signal to avoid accidental wake‑ups
  • Automatic RF transceiver switching and protocol conversion
  • Flexible parameter configuration through software or microcontroller commands
  • Standard 2.54mm pin interface with TTL signal level
  • Built‑in watchdog for long‑term stable operation
  • Open‑field node communication distance up to 2–3 km
  • Wireless sensor networks
  • Industrial telemetry and remote monitoring
  • Long‑range IoT communication systems
  • Smart agriculture data networks
  • Robotics and autonomous system communication
  • Environmental monitoring stations
  • Distributed MESH networking experiments and prototyping
  • Operating Voltage: 3.3 - 5.0V
  • Operating Frequency Band: 433MHz
  • Output Power: ≤ 20dBm
  • Receiving Sensitivity: -148dBm
  • Emission Current: ≤100mA
  • Standby Current: ≤ 20mA
  • Communication Interface: TTL serial communication
  • Serial Speed: 1200 ~ 115200, 9600bps (default)
  • Operating Temperature: -40 °C - +85 °C
  • Dimension: 34.2 * 18.4 mm
  • LoRa MESH Radio Module - 433MHz ×2
  • 433MHz Antenna (2m SMA‑Male Connector) ×2
    Only 15 Left
