LoRa Radio Module - 868MHz
$39.90
SKU: TEL0115
A long-range, low-cost transceiver module for unlicensed ISM bands, featuring star networking, high sensitivity, and customizable parameters.
JX-660T LoRa Radio Module (V2) is a compact long‑range wireless transceiver designed for reliable low‑power data communication in industrial and embedded systems. Built around the Semtech SX1262 RF chip integrated with an Arm Cortex‑M4 MCU (ASR6601), this LoRa communication module delivers enhanced sensitivity, strong interference resistance, and efficient power management. Operating in the 380–450MHz band and supporting UART communication, the wireless serial transceiver enables straightforward integration with microcontrollers and embedded controllers. Ultra‑low sleep current, adjustable transmission parameters, and extended packet capacity make this LoRa data communication module suitable for remote sensing networks, industrial telemetry, and long‑distance IoT links.
SX1262-Based Architecture with Integrated MCU
This long‑range RF communication module integrates the ASR6601 chipset combining the Semtech SX1262 LoRa transceiver with a 32‑bit Arm Cortex‑M4 microcontroller. The architecture improves link reliability, receiver sensitivity, and energy efficiency compared with previous SX127x‑based designs. Advanced forward error correction (FEC) with interleaving encoding significantly strengthens anti‑interference capability, allowing stable wireless communication even in electrically noisy environments such as industrial monitoring systems, remote infrastructure telemetry, and automated equipment networks.
High Efficiency Long‑Range Communication
This LoRa spread‑spectrum transceiver supports adjustable transmit power up to 22dBm and receiver sensitivity reaching extremely low levels for extended communication distance. Multiple spreading factors and selectable bandwidth options enable flexible optimization between range, data rate, and power consumption. Such adaptability allows the wireless telemetry module to perform effectively in long‑distance sensor networks, rural IoT infrastructure, environmental monitoring installations, and other deployments where stable low‑bitrate communication is essential.
Flexible UART Interface and Configurable Parameters
This UART LoRa communication module provides a TTL serial interface that simplifies wireless data transmission between embedded controllers and remote nodes. Configurable parameters include baud rate, frequency band, transmit power, and air data rate, allowing engineers to tailor the wireless link for different deployment scenarios. Support for baud rates up to 115200bps and packet sizes up to 1KB enables efficient data exchange while maintaining compatibility with a wide range of microcontroller platforms and embedded automation systems.
Industrial Power Efficiency and Advanced Networking Features
This low‑power LoRa transceiver introduces improved energy performance and several enhanced networking functions. Sleep current below 2.0µA and reduced receive current support battery‑powered remote nodes and long‑term deployments. Additional capabilities such as CAD collision avoidance, HEX addressing, instant PA3 wake‑up, and power‑saving passthrough operation improve network stability and responsiveness in star‑topology communication systems used for industrial monitoring, asset tracking, and distributed sensing networks.
Typical applications include wireless sensor networks, industrial telemetry, environmental monitoring systems, remote meter reading infrastructure, and long‑range IoT data collection. Compact dimensions, configurable wireless parameters, and strong interference immunity make this LoRa wireless communication module well suited for embedded developers building scalable low‑power RF networks across factories, agriculture deployments, infrastructure monitoring systems, and smart sensing platforms.
  • ASR6601 chipset integrating Semtech SX1262 LoRa RF and Arm Cortex‑M4 MCU
  • LoRa™ spread spectrum modulation for long‑range wireless communication
  • Transmit power up to 22dBm with adjustable levels
  • Ultra‑low sleep current <2.0µA for low‑power deployments
  • Receiver sensitivity down to -138dBm
  • UART (TTL) serial interface for simple integration
  • Configurable parameters including baud rate, frequency, and air data rate
  • Supports star topology networking (central / node / passthrough modes)
  • CAD collision avoidance and HEX addressing support
  • Maximum packet size up to 1KB
  • Industrial operating temperature range -40℃ to +85℃
  • Industrial wireless telemetry systems
  • Remote environmental monitoring networks
  • Wireless sensor networks (WSN)
  • Smart agriculture monitoring
  • Remote meter reading infrastructure
  • Long‑range IoT data collection
  • Infrastructure monitoring and automation
  • Operating Voltage: 2.1V ~ 5.5V
  • Working Frequency Band: 380-450MHz
  • Modulation: LoRa™ Spread Spectrum
  • Transmit Power: 22dBm (150mW, 7-level adjustable)
  • Receiver Sensitivity: -138dBm
  • TX Current: <125mA (@22dBm)
  • RX Current: <12mA
  • Sleep Current: <2.0µA
  • Spreading Factor: 5-32 / 6-64 / 7-128 / 8-256 / 9-512 / 10-1024 / 11-2048 / 12-4096
  • Signal Bandwidth: 125KHz / 250KHz / 500KHz
  • Wakeup Method: Instant wakeup (PA3 pin active low)
  • Networking Mode: Central / Node / Passthrough; Star topology
  • Special Features: CAD Collision Avoidance, Power-saving passthrough, HEX addressing
  • Sleep Time Range: 0.25S ~ 25S
  • Wake Time Range: 2ms ~ 64ms
  • Communication Interface: TTL Serial Communication (UART)
  • UART Baud Rate: 1200bps ~ 115200bps (Default: 9600bps)
  • UART Parity: 8E1 / 8O1 / 8N1 (Default: 8N1)
  • Low-Power UART Rate: 9600bps
  • Operating Temperature: -40℃ ~ +85℃ (Industrial)
  • Max Packet Size: 1KB (Normal mode)
  • Antenna Interface: RF pin (50Ω impedance)
  • LoRa Radio Module - 868MHz (JX-660T V2) x2
  • 868MHz antenna (2m SMA-Male connector) x2
    Only 9 Left
