3 x 18650 Battery Holder with DC2.1 Power Jack
$2.40
SKU: FIT0539
18650 battery holder for 3 cells, with ABS shell and stainless steel spring plate, outputs 11.1V via DC 2.1 jack, compatible with Arduino. RoHS certified.
Purchase this product and earn 24 reward points, which are tied to VIP membership program. Learn More >
The 18650 lithium battery is a commonly used lithium battery in electronic products. It is often used in batteries of laptop computers and power banks. 18650, which refers to a battery with a diameter of 18mm and a length of 65mm.
This 3 x 18650 battery holder has inner connection in series, DC 2.1 power jack, standard 11.1V output. You can connect Arduino directly.
  • ABS shell
  • The spring plate is nickel plated with stainless steel.
  • The material structure is firm and durable.
    • RoHs Certification
    • Battery Model: 18650
    • Cell number: 3
    • Output Voltage: 11.1 V
    • Plug form: DC 2.1 (outer diameter 5.5, inner diameter 2.1)
    • Size: 78.24mm x 59.46mm x 21.41mm/ 3.08 x 2.34 x 0.84 inches
    • Weight: 30 g
    3 x 18650 Battery Holder with DC2.1 Power Jack x1
