DSS-M15S 270° 15KG DF Metal Servo with Analog Feedback
$15.90
SKU: SER0044
  • $15.59 3+ items
  • $15.00 5+ items
  • $13.50 10+ items
The DSS-M15S servo offers a 270° control angle, large load capacity, and analog feedback for close-loop control, compatible with Arduino Servo library.
Purchase this product and earn 159 reward points, which are tied to VIP membership program. Learn More >
DSS-M15S servos have been well received by customers in these years. It has extremely wide angle range control, huge load capacity and excellent quality. This DSS-M15S with analog feedback has broken its internal potentiometer signal. This is an analog signal with 0~3.3V feedback. You can connect it to MCU to realize close-loop feedback control.
DSS-M15S 270° Metal servo with feedback is compatible with Arduino Servo library. You can drive it with Arduino Board and read the angle value from analog side.
Angle-Analog Value
Dimension
How to control DSS-M15S servos with Analog Feedback - DFROBOT
Electronic specifications
  • Operating voltage: 4.8-7.2V
  • 6V test environment
  • Operating speed (no load): 0.18 sec/60 degrees
  • Resting current: 80mA
  • Locking torque: 11.5KG*cm
  • Stall current: 1.4A
  • Standby current: 4mA
  • 7V test environment
  • Operating speed (no load): 0.16sec/60 degrees
  • Resting current: 100mA
  • Locking torque: 12KG*cm
  • Stall current: 1.76A
  • Standby current: 5mA
  • Mechanical specifications
  • Gear material: metal gear
  • Operating angle: 270 degrees
  • Wiring gauge: 28PVC
  • Data line length: 320mm
  • Gear bracket spline: 25T/5.80
  • Gear ratio: 310:1
  • Size: 54.5*20*47.5mm
  • Control specifications
  • Feedback signal: 0-3.3V
  • Control signal: RC PWM
  • Pulse range: 500-2500 us
  • Median signal value: 1500us
  • Clockwise rotation: <1500us
  • Control frequency: 50-330Hz (Arduion compatible)
  • DSS-M15S 270° servo with analog feedback x1
  • Crossed horn x1
  • Long straight horn x1
  • Short straight horn x1
  • M2*8 self-tapping screws and gasket x5
  • M3*6 screw x1
    dukwoo.lee Apr 21, 2023
    I am satisfied with the fast delivery.
