High Quality Gold Plated XT90 Male & Female Bullet Connector provides a compact, high‑current power connection solution designed for demanding electronic and robotics systems. This mini‑sized XT90 power connector reduces installation space while maintaining reliable electrical performance for battery packs, motor controllers, and high‑power modules. True gold‑plated copper contacts combined with a cross‑slot structure create a larger conductive contact area that supports continuous 40A current and peak loads up to 90A. The compact XT90 plug pair integrates insulating housing, efficient heat dissipation structure, and robust mechanical design, delivering dependable performance in high‑current DC power distribution applications.
High Current Capacity with Gold‑Plated Contacts
True gold‑plated copper banana contacts combined with a cross‑slot structure significantly increase the electrical contact area, reducing resistance and improving current transfer stability. This high‑current connector supports a continuous load of 40A and peak current up to 90A, making the XT90 interface suitable for power‑intensive electronics such as RC battery systems, electric drive modules, robotics power buses, and other DC energy delivery setups requiring stable high‑amperage transmission.
Flame‑Retardant Insulated Housing
The protective shell uses PA insulating material with a UL94 V0 flame‑retardant rating. This safety‑focused construction prevents sustained combustion after exposure to flame and automatically extinguishes once the ignition source is removed. A hollow internal structure enhances thermal dissipation, allowing this high‑power connector to operate reliably across demanding electrical loads and elevated temperatures commonly encountered in power electronics environments.
Integrated Structural Design for Reliable Connection
Banana inserts and plastic housing are combined using integrated molding technology, forming a durable structure with strong mechanical stability. A specially shaped sheath, grooved locking slot, and anti‑slip plug design improve handling and secure connection during repeated use. Waterproof vapor resistance and a user‑friendly soldering interface further simplify cable assembly, enabling fast wiring with 10AWG conductors while maintaining strong electrical integrity.
This compact XT90 battery connector pair serves as a reliable solution for high‑current DC wiring in robotics platforms, RC vehicles, battery packs, power distribution systems, and prototyping environments where durable connectors, strong current capacity, and safe insulation are essential.
