Machine Friction Disc Lock Washer Torque Limiter Coupling
$129.00
SKU: FIT0589
Torque limiter TL350-2 protects by limiting torque in drive systems, re-engaging after overload. Features a 22.23mm inner hole, 34-149N*m torque range, and 2.48 kg weight.
Purchase this product and earn 1290 reward points, which are tied to VIP membership program. Learn More >
TL350-2 torque limiter is a mechanical overload protection component designed to restrict transmitted torque in rotating drive systems. When shock loads, sudden overloads, or mechanical jams push torque beyond a preset threshold, controlled friction slipping occurs to prevent damage to motors, gearboxes, and transmission elements. Once the overload condition disappears, normal torque transmission automatically resumes without manual resetting. This adjustable friction‑type coupling serves as a reliable safeguard for industrial motion assemblies, conveyor drives, automated machinery, and experimental mechanical systems where stable torque control and equipment protection are essential.
Adjustable Friction Torque Protection
A spring‑loaded friction plate mechanism allows precise presetting of slip torque. Adjustment is achieved by tightening or loosening a nut or bolt that controls spring compression, which changes the friction force between plates. Once torque demand exceeds the configured threshold, controlled slipping occurs to absorb excess load and protect connected components. This friction‑based torque limiting method provides reliable mechanical protection in systems vulnerable to sudden overload conditions.
Flexible Integration in Drive Assemblies
The mechanical torque control unit functions as a central connection element within a power transmission chain. Sprockets, gears, sheaves, or flange plates can be mounted between friction surfaces, enabling integration into many drive configurations. The compact mechanical structure supports installation in industrial automation equipment, transmission test rigs, and motion control mechanisms that require a dependable overload protection coupling.
Applications include conveyor protection systems, automated production machinery, drivetrain testing platforms, mechanical power transmission assemblies, and robotics motion experiments where drivetrain safety and controlled torque limiting are necessary for reliable operation.
  • Spring-loaded friction torque limiting mechanism
  • Adjustable slip torque using nut or bolt compression
  • Automatic re-engagement after overload removal
  • Compatible with sprockets, gears, sheaves, and flange plates
  • Durable 45 steel body with non‑asbestos friction material
  • Designed for mechanical drivetrain protection
  • Industrial conveyor protection systems
  • Mechanical transmission assemblies
  • Automation equipment drivetrain safety
  • Robotics mechanical drive experiments
  • Machine overload protection mechanisms
  • Type:TL350-2(With special keyway and inner hole)
  • Inner hole diameter: 22.23mm
  • Keyway width: 4.78mm
  • Torque range: 34~149N*m
  • Maximum speed: 5600
  • Weight: 2.48 kg
  • Material: the main body is 45 steel, the friction plate is non-asbestos material
  • Machine Friction Disc Lock Washer Torque Limiter Coupling x1
Only 3 Left
