Machine Friction Disc Lock Washer Torque Limiter Coupling
$129.00
SKU: FIT0589
Torque limiter TL350-2 protects by limiting torque in drive systems, re-engaging after overload. Features a 22.23mm inner hole, 34-149N*m torque range, and 2.48 kg weight.
Purchase this product and earn 1290 reward points, which are tied to VIP membership program. Learn More >
Torque limiter is a protective device that limits the torque transmitted in a drive system by slipping when the torque demand exceeds a preset value as a result of shock loads, overloads, or machine jams. It automatically re-engages when the overload is removed.
This model TL350-2 uses a spring-loaded friction surface to adjust the spring force with a nut or bolt to preset the sliding torque. It can be used as a center member with a sprocket, a gear sheave or a flange plate, sandwiched between the friction surfaces.
  • Type:TL350-2(With special keyway and inner hole)
  • Inner hole diameter: 22.23mm
  • Keyway width: 4.78mm
  • Torque range: 34~149N*m
  • Maximum speed: 5600
  • Weight: 2.48 kg
  • Material: the main body is 45 steel, the friction plate is non-asbestos material
  • Machine Friction Disc Lock Washer Torque Limiter Coupling    x1
Only 3 Left
