Holiday Shipping Notice: DFRobot will be out of office Sep 30 – Oct 7 (UTC+8) for the National Day holiday. Shipping resumes Oct 8.
Monocrystalline Solar Panel (5V 1A)
$9.00
SKU: FIT0601
Lightweight, portable solar panel with 5V output, USB port, and voltage regulator, ideal for various environments. Efficient when paired with a solar management board.
This is a high-performance, lightweight, portable monocrystalline silicon solar panel in a PET package, with an integrated voltage regulator output of 5V, with working indicators, USB type-A mother-port output, plug-and-play. It can supply plenty of power in various environments to prevent the system from shutting down, even in rainy days.
The energy of solar panel will be particularly efficient when paired with the DFRobot solar power management board. The panels are provided with open holes and copper clasps so that they can be attached directly to the backpack for easy portability and use. The ultra-thin, lightweight design weighs just 90g. It's much lighter than a solar panel in a traditional glass package.
When you hang this panel, make sure the panel is facing the sun and there is no shade covering the solar panel.
  • Operating Voltage: 5V (With voltage regulator module)
  • Open-circuit Voltage: 7.2V
  • Operating Current: 1A(MAX)
  • Short circuit current: 1.1A
  • Maximum power: 6W
  • Material: Monocrystalline Silicon Flexible Lamination
  • Wire length: 1m
  • Product size: 275*170*2.5mm
  • Working temperature: -30℃~70℃
  • Monocrystalline Solar Panel (5V 1A) x1
    Automatic Plant Watering System using Raspberry Pi Pico
    Projects Automatic Plant Watering System using Raspberry Pi Pico
    Rahul Khanna D
    May 22, 2021
    How to Create a Solar-Powered Balcony Plant Soil Moisture Monitoring System with ESP32-C6
    Projects How to Create a Solar-Powered Balcony Plant Soil Moisture Monitoring System with ESP32-C6
    auroraAA
    Jul 09, 2024
    David.Savells Aug 28, 2026
    Nice Solar Panel. Durable construction and heavy duty mounting points.
    Ange Salem Carlos.AKPINFA Sep 09, 2025
