Semi Flexible Monocrystalline Solar Panel (6V 1A)
$17.50
SKU: FIT0600
Lightweight, waterproof monocrystalline solar panel with 5V 1A output. Ensures reliable power in various environments, easy to carry and attach to backpacks.
Purchase this product and earn 175 reward points, which are tied to VIP membership program. Learn More >
Note: The working voltage is 5V 1A, the open circuit voltage is 6V 1A, and it is compatible with the Solar Power Manager 5V.
This powerful monocrystalline solar panel features an A-class monocrystalline silicon panel. Due to up to 21% conversion efficiency and waterproof design, you don't have to worry about rains. It can supply plenty of power in various environments to prevent the system from shutting down, even in rainy days.
The panels are provided with open holes and copper clasps so that they can be attached directly to the backpack for easy portability and use. The ultra-thin, lightweight design weighs just 87g. It's much lighter than a solar panel in a traditional glass package.
When you hang this panel, make sure the panel is facing the sun and there is no shade covering the solar panel.
monocrystalline silicon has two shapes, but does not affect the performance, will be shipped randomly.
  • Operating Voltage: 5V
  • Operating Current: 1A
  • Maximum power: 5W
  • Open-circuit Voltage: 6V
  • Short circuit current: 1.1A
  • Material: Monocrystalline Silicon Flexible Lamination
  • Wire length: 1m
  • Product size: 29*15*0.135cm / 11.41*5.9*0.05 in
  • Working temperature: -20 ° C ~ 60 ° C
  • Semi Flexible Monocrystalline Solar Panel (6V 1A) x1
