Embedded Thermal Printer V2.0
$39.00
SKU: DFR0503-EN
The thermal printer offers stable, ink-free performance, supports various systems, and prints text, barcodes, and images. Ideal for DIY projects and remote printing.
Purchase this product and earn 390 reward points, which are tied to VIP membership program. Learn More >
The micro thermal printer utilizes thermal printing technology, eliminating the need for ink or toner. It offers stable performance, compact size, and space-saving design. Operating at 9–24V wide voltage, it delivers clearer prints at higher voltages. Compatible with 58mm thermal paper rolls, it supports a printing lifespan of up to 50 kilometers. This printer is widely used in instrumentation, food testing, retail terminals, and embedded applications such as ATMs, lockers, POS systems, electronic scales, and takeaway machines. It supports Arduino, Raspberry Pi, and Windows via serial port or driver printing, enabling text, barcodes, QR codes, and even black-and-white graphics.
Versatile Connectivity Options
The printer supports multiple communication interfaces, including TTL, USB, RS485, and RS232, ensuring seamless integration with various systems. It is compatible with Arduino and Raspberry Pi, making it ideal for DIY projects and embedded solutions.
Dual Printing Modes
Featuring both receipt and label printing modes, the printer can be switched via commands, offering flexibility for different application needs. This makes it suitable for retail, logistics, and industrial labeling scenarios.
High-Speed, High-Resolution Printing
With a resolution of 203DPI (8 dots/mm) and a printing speed of 70mm/s, the printer delivers sharp, efficient outputs for text, graphics, barcodes, and QR codes. Its effective printing width of 48mm ensures clear and legible content.
Long Lifespan & Low Power Consumption
The printer boasts a printing lifespan of up to 50 kilometers and a standby current of just 0.02A, ensuring durability and energy efficiency. Its wide operating temperature range (-5°C to 50°C) makes it reliable in various environments
Embedded Thermal Printer - TTL Serial Connection Diagram
Note:
1. The V2.0 printer has two printing modes, receipt printing and label printing. The mode can be switched through commands
2. The power supply of the V2.0 printer is 9-24V
  • Working voltage: DC9~24V
  • Working current: 0.5~2.5A
  • Standby current: 0.02A
  • Communication interface: TTL+USB+485+RS232
  • Printing method: Line thermal printing
  • Printing mode: Receipt printing/label printing
  • Printing color: Black and white output
  • Resolution: 203DPI (8 dots/mm, 0.125mm/dot, 384 dots per line)
  • Consumables: Thermal receipt paper roll, thermal label paper roll
  • Paper roll specifications: Paper roll width (58mm±0.5mm), paper roll diameter (30mm)
  • Printing content: Support text , graphics, one-dimensional barcode, two-dimensional code, curve, etc.
  • Printing width: 48mm (effective printing width)
  • Printing life: 50 kilometers
  • Printing speed: 70mm/s
  • Printing characters: GB18030 Chinese character library (2424 international first and second level character library), 1224 standard ASCII code, and can enlarge Chinese characters and characters by 1-4 times
  • Working temperature: -5℃~50℃
  • Working humidity: 25%~50%RH
  • Storage temperature: -20~70%°C
  • Storage humidity: 5~95%RH
  • Appearance size: 82*58*44 mm
  • Installation size: 77*53*42 mm
  • Embedded thermal printer x1
  • 2PIN power cable x1
  • 4PIN communication cable x1
  • 4PIN USB data cable x1
  • Thermal receipt paper roll x1
  • Thermal label paper roll x1
    Transform Your Note-Taking with Telegram & Arduino Nano 📋
    Projects Transform Your Note-Taking with Telegram & Arduino Nano 📋
    Kutluhan Aktar
    Dec 30, 2020
    Web-Enabled ML Mask Detection Robot Fines w/ Penalty Receipt
    Projects Web-Enabled ML Mask Detection Robot Fines w/ Penalty Receipt
    Kutluhan Aktar
    Dec 02, 2020
    AI-driven Dental Cast (Model) Classifier w/ Edge Impulse
    Projects AI-driven Dental Cast (Model) Classifier w/ Edge Impulse
    Kutluhan Aktar
    Jul 14, 2022
    AI-driven IoT Shopping Assistant w/ ChatGPT
    Projects AI-driven IoT Shopping Assistant w/ ChatGPT
    Kutluhan Aktar
    Aug 21, 2023
    Kutluhan Aktar
    Nov 17, 2022
    Telegram-Enabled Thermal Printer w/ Arduino Nano 33 IoT
    Projects Telegram-Enabled Thermal Printer w/ Arduino Nano 33 IoT
    Kutluhan Aktar
    Nov 17, 2022
    Only 17 Left
