180 degree swivel base manipulating platform(Discontinued)
SKU: ROB0038
Discontinued
ROB0038 to 5 degrees of freedom manipulator with the market, combined into a 6-DOF manipulator. 6DOF manipulator rotating base
180 degree swivel base 6DOF robot arm, can be used with most of the 5-DOF manipulator on the market, adopting the base resin insulation board processing, high strength, non-friable, non-conductive.
Base includes a rotating actuator, can easily turn around 90 degrees above the base load 5Kg. Base can be directly installed USB 32 Servo Controller and Arduino Duemilanove way controller.
  • Dimensions: 230 x 120 x 60mm
  • 5kg or more can be load-bearing
  • Weight: 150g
  • ARM Mounting Board 1 1 piece
  • ARM Mounting Board 2 1 piece
  • ARM Mounting Board 3 1 piece
  • ARM Mounting Board 4 1 piece
  • M4 * 8 screw nut 6 sets
  • M3 * 30 single head Cylinders 5
  • M3 * 10 single head Cylinders 18
  • M3 * 6 Cylinder and 4 single-head
  • Screw M3 * 5 16
  • Capped nut M3 20
  • Servo drive from the wire-tapping screws 4
  • DF05BB steering gear 1
