Six Arm Soldering Station
$29.90
SKU: FIT0609
A third hand soldering station with six flexible arms, an aluminum base, rotating alligator clips, and grooves for screws. Includes a free USB fan.
This is a third hand soldering station with six flexible helping arms and an aluminum alloy base, allowing you to finish all kinds of complicated welding work. Aluminum-made base and rubber pad of the product are able to keep the soldering station from sliding around on your bench, which greatly ensures stability. The six adjustable flexible arms can easily hold anything that is going to be soldered. We also set freely-rotating alligator clips on the top of the arms to convenient your operation. The grooves on the base can be used to place your screws and other material. A free USB fan is included in the package.
  • Universal Joint Pipe Length: 11 inches
  • Aluminum Alloy Base Dimension: 2.7”×4.5”
  • Aluminum Alloy Base      x1
  • Universal joint pipe        x6
  • Non-Slip Rubber Pad      x6
  • Alligator clip              x6
  • USB Fan                   x1
Mingkwunrak.Wonchana Feb 04, 2025
This product is a good quality product. You can see from the product itself that it uses good quality materials. The plastic looks good quality.
Yan.Nyein Aug 26, 2021
Very useful for diy guys especially both hands are busy.
Only 5 Left
