64×32 Flexible RGB LED Matrix (4mm Pitch) provides a lightweight and bendable alternative to conventional rigid RGB LED panels used in creative displays and embedded visual systems. Measuring 256×128mm with a dense 4mm pixel pitch, this programmable RGB matrix delivers vivid full‑color graphics across 2048 pixels while maintaining a slim, adaptable structure. Compared with traditional rigid LED display boards, the flexible display module enables curved surfaces, wearable installations, creative signage, and space‑constrained builds. Support for high‑speed controllers such as Raspberry Pi and Mega 2560 makes the programmable LED panel suitable for interactive installations, robotics interfaces, and embedded visualization projects.
Note: Do not bend the panel beyond 30° or repeatedly flex the surface, as excessive deformation may damage the flexible LED structure. Arduino Uno boards cannot provide sufficient memory for driving this display. A high‑RAM controller such as Raspberry Pi or Mega 2560 is recommended. During operation, the LED matrix requires an external power supply to ensure stable brightness and complete screen rendering.
Flexible Construction for Creative Installations
The bendable RGB display board introduces mechanical flexibility rarely available in standard LED matrices. A thin, lightweight substrate allows gentle curvature along surfaces such as cylindrical columns, wearable props, exhibition structures, and artistic lighting displays. This adaptable LED display module expands installation possibilities in environments where rigid panels cannot conform to shapes or space limitations. Designers gain freedom to integrate dynamic pixel graphics into curved enclosures, stage decorations, interactive art pieces, or unconventional architectural forms.
High‑Density 64×32 RGB Pixel Array
A 64×32 resolution layout with a 4mm pixel pitch produces a total of 2048 individually addressable RGB LEDs, delivering detailed animations, scrolling text, and colorful visual patterns. The compact pixel spacing improves visual clarity at moderate viewing distances while maintaining strong brightness and wide viewing angles exceeding 160°. Combined with refresh rates above 300Hz, this flexible LED display board supports smooth animation rendering suitable for digital signage prototypes, information displays, and real‑time graphical interfaces.
Expandable Display System via Cascading Connectors
Dual IDC connectors labeled DATA_IN and DATA_OUT allow multiple panels to be chained together, enabling construction of larger programmable LED walls or extended information displays. Cascading capability supports scalable visual systems for exhibitions, robotics dashboards, event signage, or stage backgrounds. When paired with high‑performance development platforms such as Raspberry Pi or Mega 2560, the modular RGB matrix array becomes a powerful visual output component for interactive electronics and embedded display applications.
This flexible RGB LED panel fits a wide range of projects including creative signage, robotics visual interfaces, interactive exhibits, and experimental display systems. Curved installation capability combined with expandable panel cascading makes the module valuable for makers, research labs, digital art creators, and STEM Education environments exploring programmable lighting and visual computing.
