Digital RGB LED Strip 120 LED-White
$11.90
SKU: FIT0613
The LED strip offers vibrant, controllable RGB lighting with 256 brightness levels. It's flexible, can be bent or cut, and is ideal for DIY projects.
If you are going to make something dazzling and colorful, then you have come to the right place. Now, DFRobot is launching this Digital RGB LED Strip.
This WS2812 RGB LED strip is composed of a series of colorful LEDs. All of the LEDs can be controlled by us with just one signal line. Each LED is an individual pixel point that consists of the three primary colors: red, green and blue. It is able to achieve 256 levels brightness display and 16777216 full color display. Meanwhile, we set intelligent digital port data latch and signal reshaping amplification drive circuit inside the LED, greatly ensuring the consistency of pixel point light color.
With good flexibility, this strip of pure color can be arbitrary bent or cut off. The adhesive tape on the back of the LED strip makes it able to be fixed on anywhere. Power it up, you will be in a magical and colorful world in seconds. They can be used in home decoration, festival interactive activity, intelligent LED, shining DIY device, and so on.
  • Input Voltage: 5V
  • Power Factor: 20
  • Beam Angle: 120°
  • LED Quantity: 120
  • Width: 10MM
  • Length: 2M
  • WS2812 RGB LED Strip 120 LED-White x1
    RGB HexMatrix | IOT Clock
    Projects RGB HexMatrix | IOT Clock
    Mukesh Sankhla
    Feb 12, 2021
    jérémi.darien May 10, 2025
    This is an amazing product
