64x32 Flexible RGB LED Matrix-5mm Pitch
$69.00
SKU: DFR0596
A 64x32 flexible RGB LED matrix with a 5mm pixel pitch, ideal for creative designs. Requires external power, compatible with high-speed microcontrollers.
If you have tried our 64×64 or 64×32 RGB LED Matrix Panel, but you had to give up some of your original ideas and designs out of the limitation of thickness and weight of the product, why not try this 64 ×32 flexible RGB LED Matrix. I assure you it will be an excellent choice for you. With a size of 320×160mm and flexible feature, it can almost meet all your needs.
Please don’t bend the product over 30° or repeatedly bend it in case causing product damage. In addition, same as normal matrix panel, this screen also cannot work with Uno board. We recommend using microcontrollers with large RAM and high speed to control the LED such as Raspberry Pi, Mega 2560 etc. The LED matrix has two IDC connectors (DATA_IN, DATA_OUT) on the back, which enable you to cascade multiple panels and make a huge screen. Please provide external power supply for the LED matrix during operation, otherwise the screen display will be unclear or incomplete.
Compared with Flexible RGB LED Matrix-4mm Pitch, this matrix screen has larger Pixel pitch and areas.
64x32 Matrix with NodeMCU | DFRobot | NodeMCU
  • Pixel Pitch: 5mm
  • Operating Voltage: 5V
  • Maximum Power Consumption: ≤12W
  • Repetition Frequency: ≧360Hz
  • Refresh Frequency: ≧500Hz
  • Viewing Angle: ≧160°
  • Resolution: 64x32=2048Dots
  • Optimal Visual Distance: 5-58M
  • Dimension: 320x160mm/12.60x6.30”
  • 64x32 Flexible RGB LED Matrix-5mm Pitch x1
  • IDC to XH2.54 Cable x1
  • IDC to IDC Cable  x1
  • Power Supply Cable  x1
jesse. Nov 03, 2022
Pros: Lightweight, very bright, compatible with standard matrix controllers Cons: Fragile, and won't come with .rcvbp configuration files (you'll have to trial and error to create them yourself if you want to use a controller that requires it).
Hugo. Nov 20, 2020
L'emballage du produit était parfait. Arrivé en temps et en heure. Je n'hésiterais pas à repasser commande ici.
Only 8 Left
