2.13" e-ink Display Module for Raspberry Pi 4B/3B+/Zero W
$17.00 $22.90
SKU: DFR0591
2.13" e-ink display module for Raspberry Pi, with SPI interface, supports custom fonts, low power, clear sunlight visibility, and maintains last image when off.
Purchase this product and earn 170 reward points, which are tied to VIP membership program. Learn More >
This Raspberry Pi e-ink display module comes with a 2.13" screen with a resolution of 250×122, adopting SPI interface to communicate with Raspberry Pi. It leads out the pins on Raspberry Pi, so there would be no conflicts if you need to use the e-ink display and Raspberry Pi’s pins at the same time. The display supports custom font. There are two patch touch switches on the module for expanding more applications. This e-ink display features small size, compact layout, plug and play, and low power consumption. It can provide clear display even in sunlight. When powered off, the e-ink display will continue to display the last screen. Since it will take a long time for the display to refresh fully, we don’t recommend using the product in the application that needs frequent refreshing to display data.
  • Operating Voltage: 3.3V
  • Resolution: 250 x 122
  • Interface Type: SPI
  • Color: black, white
  • Refresh Way: fully or partially refresh
  • Refresh Time: 3s for full refresh, 680ms for partial refresh
  • Refresh Power: 26.4mW(typ.)
  • Standby Power: 0.017mW
  • Visual Angle: >170°
  • Connector: 2.54mm 2*20pin
  • Dimension: 66.5 x 31 mm/2.62x1.22”
  • Storage Temp: -20℃~+60℃
  • Raspberry Pi e-ink Display Module x1
  • Double Nuts Copper x2
  • Screw x4
Damjan. Oct 28, 2022
Excellent e-ink display.
Only 10 Left
