PH2.0-3P Cable F/F (10 Pack)
$4.90
SKU: FIT0627
  • $4.75 3+ items
  • $4.65 5+ items
  • $4.50 10+ items
The PH2.0 3Pin cable, measuring 5cm, resolves connection issues between Boson modules and Arduino IO shields. Comes in a pack of 10 cables.
PH2.0 3Pin Cable F/F provides a simple wiring extension solution for Boson modules and other PH2.0 interface electronics. Compact 3‑pin jumper cables frequently become a limitation when prototyping robotics projects, classroom experiments, or rapid hardware setups. This short PH2.0 female‑to‑female cable extends the connection distance between Boson components and development hardware such as the Boson Kit or the Arduino IO expansion shield. A flexible connector layout allows fast integration without soldering, making this extension lead useful for modular electronics systems, quick prototyping benches, and educational hardware assemblies where clean and reliable cable routing is required.
Flexible PH2.0 Extension for Modular Electronics
This PH2.0 interface extension cable increases wiring reach between compact sensor modules and controller boards in modular electronic systems. Many plug‑and‑play platforms rely on short connectors that limit layout flexibility on robotics frames or classroom prototypes. A 5 cm female‑to‑female PH2.0 cable provides additional routing freedom while maintaining secure three‑pin connectivity for signal, power, and ground. The compact extension lead fits naturally into Boson‑style modules and similar PH2.0 connector ecosystems, supporting rapid hardware rearrangement during prototyping or iterative circuit testing.
Reliable Connector for Quick Prototyping
A precision PH2.0‑3P female connector on both ends enables direct module‑to‑board extension without adapters or soldering. This small prototyping accessory helps bridge compatibility gaps when Boson modules require additional cable length or when interface positions differ from expansion shields and controller boards. Stable connector alignment ensures consistent electrical contact across power and signal lines, supporting dependable operation in educational experiments, embedded development setups, and modular robotics assemblies built around PH2.0 connection standards.
Compact PH2.0 jumper cables serve well in electronics prototyping, STEM classroom kits, robotics builds, and modular sensor experiments. Extension leads simplify layout adjustments when modules require repositioning or when expansion boards sit farther apart inside enclosures or project frames. Such connector accessories help maintain neat wiring while preserving plug‑and‑play convenience across modular hardware ecosystems.
  • PH2.0 3‑pin female to female connector cable
  • Designed for Boson modules and PH2.0 interface electronics
  • Extends connection distance between modules and controller boards
  • Plug‑and‑play wiring without soldering
  • Compact and flexible cable for prototyping setups
  • Suitable for robotics, electronics projects, and STEM learning kits
  • Boson module project wiring
  • Educational electronics kits
  • Robotics module connections
  • Prototype circuit extension
  • Sensor module wiring in STEM laboratories
  • Interface:PH2.0-3P Female
  • Size:5cm
  • PH2.0-3p Cable F/F x10
    UNIHIKER, NFC, and LEDs: A Story of Interaction and Color
    Projects UNIHIKER, NFC, and LEDs: A Story of Interaction and Color
    Lupin
    Jul 15, 2024
    Only 12 Left
