Gravity: Shiftout Module
$4.20
SKU: DFR0072
The shift register module expands Arduino outputs using 74HC595, controlling 8 outputs with few pins. It's compatible with multiple microcontrollers.
Purchase this product and earn 30 reward points, which are tied to VIP membership program. Learn More >
The 74HC595 ShiftOut Module provides a practical method for expanding digital output capacity when limited GPIO pins restrict project design. Built around the widely used 74HC595 serial‑in/parallel‑out shift register, this output expansion board enables a microcontroller to control eight digital outputs while consuming only a few control pins. Such capability makes the module especially useful for LED driving, relay control, and other multi‑channel switching tasks. Compatible with popular development platforms including Arduino as well as 51, AVR, and PIC microcontrollers, this compact expansion solution simplifies scalable hardware design for embedded electronics and maker projects.
Efficient GPIO Expansion with 74HC595 Architecture
A reliable 74HC595 shift register forms the core of this digital output expansion module. The chip architecture supports 8‑bit serial data input and parallel output with output latches and three‑state control. Such architecture enables a microcontroller to transmit serial data while simultaneously updating multiple outputs. Through this method, eight independent output channels become available while occupying only a few MCU pins. The design greatly reduces pin consumption and simplifies circuit routing in robotics controllers, LED matrices, and embedded control systems requiring multiple digital outputs.
Daisy‑Chain Scalability for Large Output Systems
Multiple shift register boards can be cascaded to dramatically increase available outputs without additional microcontroller pins. By linking registers in series, complex digital control systems such as large LED arrays, display panels, or multi‑relay automation setups become straightforward to implement. IDC6 connectors provide convenient signal routing between modules, enabling rapid expansion while maintaining stable signal timing. Such scalability allows this microcontroller output expander to serve both small educational prototypes and larger embedded hardware projects requiring dozens of controlled output channels.
Integration into existing hardware setups remains simple thanks to standardized connectors and compatibility with common development ecosystems. Pairing the shift register expansion board with accessories such as the Interface Shield for Arduino. enables quick prototyping and clean wiring. Applications range from LED control systems and relay boards to interactive installations and STEM Education electronics experiments that demonstrate serial‑to‑parallel digital control.
  • Based on the 74HC595 8‑bit serial‑in, parallel‑out shift register
  • Expands microcontroller outputs while using only a few control pins
  • Supports cascading multiple modules for large output arrays
  • IDC6 input and output connectors for convenient module linking
  • Compatible with Arduino, 51, AVR, PIC and other microcontrollers
  • Suitable for LED control, relay switching, and digital output expansion
  • LED array and LED matrix control
  • Relay and multi‑channel switching systems
  • Microcontroller digital output expansion
  • Interactive electronics and display projects
  • Embedded system prototyping and STEM education experiments
  • Voltage: 5V
  • Input Interface: IDC6
  • Output Interface: IDC6
  • Module Size: 41 × 22mm (1.6 x 0.9in)
  • Shiftout Module x1
  • Only 18 Left
