Inclined Electromagnetic Lock (12V)
$7.90
SKU: FIT0624
  • $7.70 3+ items
  • $7.50 5+ items
  • $7.30 10+ items
This 12V electromagnetic lock is durable, anti-corrosion, and features a rotating bolt for compatibility with various doors. Ideal for smart home and security applications.
This 12V electromagnetic lock comes with two control wires(red: +, black: -). Power up/off to unlock/lock the electromagnetic lock. We add an electroless nickel plating onto the metal surface of the shell and frame to make the lock durable and anti-corrosion. The bolt and lock hole are made of pure-copper, smooth, and never get stuck. Meanwhile, the bolt can be rotated to 90, 180 or 270 to match any doors you want to use it with. When the coil of copper wire inside the lock is energized, the bolt will be pulled into the center of the coil immediately. The electromagnetic lock features good heat resistance and long service life.
Use this electromagnetic lock together with relay modules and micro-controllers to build up smart home, or use it to lock sales machines, storage racks, file cabinets, automated equipment and so on.
Connection Diagram
  • Operating Voltage: 12V
  • Operating Current: 0.4A
  • Electrify Time: unlimited
  • Stroke: 10mm
  • Suction Force: ≤1N(0.1kg)
  • Working Principle: power on, the lock retracts, power off, the lock pops out
  • Product Size: 55mm*23mm*28mm/2.17*0.91*1.10”
  • Material: nickel plating shell, pure copper coil
  • Applications: drawers, storage cabinets, showcase, sale machines, etc.
  • Inclined Electromagnetic Lock-12V x1
  • DC2.1 Female Terminal Connector x1
    Smart Arduino Digital Meter with HC-SR04 and TM1637
    Projects Smart Arduino Digital Meter with HC-SR04 and TM1637
    cstram
    May 29, 2021
    IoT | Telegram Fingerprint Door Lock and Surveillance Camera w/ Night Vision
    Projects IoT | Telegram Fingerprint Door Lock and Surveillance Camera w/ Night Vision
    Kutluhan Aktar
    Nov 17, 2022
    David. Feb 09, 2026
    Seems to work very well
