The screen supports two operating system: Windows and Linux (touchscreen is not available for MACOS). It can work with Lattepanda, Raspberry Pi and other devices with HDMI output, which can truly be totally compatible with all platforms. The design of the special hole on the back of the screen is convenient for the direct installation of the display in Raspberry Pi controller.
There is no need to provide an external power supply for the screen as it can be directly powered by USB port. In addition, the hardware backlight of this display can be adjusted through host systems, convenient to use.
Note: the current structure is only designed for Raspberry Pi. You may need to purchase a suitable HDMI cable for other host connections.
Operating Voltage: 5V
Operating Current: 700mA
Resolution: 1080*1920
Video Interface: HDMI
Touch/Power-supply Interface: Micro-USB
Support 10 Touch Points
Display Area: 68.3mm x 121.42mm
Outline Area: 138mm x 81mm
Mounting Hole Size: M2.5
Outer Mounting Hole: 95mm x 64mm
Inner Mounting Hole: 58mm x 49mm (Raspberry Pi compatible)
